Closed Thread
Old 04-18-2008, 03:13 PM   #1
My5ABaby
My5ABaby's Avatar
Suspension kits
Ok, I'm redoing my subframe/suspension area (rubber, bushing, etc.) and I'm curious about some things. Basically, I need all the rubber and ordering it through Mazda is expensive as hell. I've looked at kits such as Energy Suspension but I'm not sure which pieces they can be substituted for.
Mazdatrix has quite a few kits (which I've emailed them about and have yet to hear back).
Anti-Sway Bar Bushing Sets
- One set needed to fit the Front bar. 24mm bar only.
- One set needed to fit Rear bar (14mm bar only)
Front or Rear Sway-Bar End Link Bushings
These are pressed into the stock links (86-88 only) to replace the factory rubber bushings. One set needed per end of car.
Front Lower Control Arm Bushing Kit (86-92)
This is a really good kit that contains the bushings needed for the front and the rear pivots of the front control arm. The inner diameter has the "barb" shape to conform to the OEM arm. Complete with the needed steel sleeves and bushings to do both arms.
- Front Lower Control Arm Bushing Kit
- Front Lower Control Arm Bracket
Rear Lower Control Arm Bushing Kit
This kit does the front pivots of the rear lower swing arm. Complete with bushings and sleeves to do both arms.
HYPER-FLEX SYSTEM Complete Master Bushing Set (Energy Suspension):
- Front and rear control arm bushings
- Front and rear sway bar bushings
- Ball joint boots
- Tie rod end boots
Here's the list of what I'm wanting:
Rear Suspension
Stopper-Rear Damper Rubber 2 FB01-28-014
Spring Rear Damper Sheet 2 FB01-28-040
Mounting-Rear Damper Plate 2 FB01-28-050
Rear Damper Stopper 2 FB01-28-030A
Rubber-Rear Damper Bushing 2 F044-28-015
Rubber-Rear Damper Bushing 2 F044-28-013
Rear Damper Plate Set 2 FB01-28-020
Rear Damper Spacer 2 FB01-28-025
Rear Stabilizer
Stabilizer Rear Bushing 2 FB43-28-156A
Rear Lower Arms & Sub-Frame
Rubber-Rear Lower Arm Bushing 2 FB01-26-220
Pillow-Rear Lower Arm Ball 2 FB01-26-230
Seal-Rear Lower Arm Rubber 4 FB01-26-250
Lower Arm Bushing 4 FB01-28-460
Sub-Frame Rubber 2 FB43-28-840
Mounting-Differential Rubber 2 FB01-28-890C
Rear Axle
Lower Arm Stopper 2 FB01-26-335
Seat-Bearing Housing Rubber 2 FC01-26-410
Front Suspension Mechanisms (1-M13)
Stop Bumper (Bound Bumper) 2 FB01-34-111A
Spring Cushion (Rubber Sheet) 2 FB01-34-012
Spring Seat 2 FB01-34-341
Damper Cap 2 FB01-34-019
Rubber Lower Arm Bushing 2 FB01-34-460
Rubber Front Bushing 2 FB01-34-470
Crossmember and Stabilizer (1-D14)
Stabilizer-Front Rubber 2 FB43-34-156
Differential
Mounting-Differential Casing Rubber 2 FC01-28-980
Front
Community Service Manual
RotorWiki
My5ABaby is offline
Old 04-18-2008, 04:47 PM   #2
RoughRex
Out of Nickels and Dimes
RoughRex's Avatar
Are you really gonna make us look at the FSM so we can understand that? :P
When I did my suspension I bought the springs(eibach), sways(eibach), strut top mounts(Tokico), and struts(Tokico HP) off of ebay. I got the rest of the small rubber parts from the dealer except for the boots which I got from some other web vendor. I also got the front and rear control arm bushings(energy) off of ebay and I got all my drivetrain mounts from Ray Crowe at Malloy Mazda. Those were the cheapest places I could find to get those parts, I hope that helps.
1988 GXL
RoughRex is offline
Old 04-18-2008, 05:30 PM   #3
You already have a thread just like this.
Thread closed.
djmtsu is offline
Closed Thread
