|  02-04-2012, 09:12 AM | #31 | |
| Rotary Fan in Training Join Date: Apr 2009
				Rep Power: 0  | Quote:
 here is what I have thought about. 1. I raced my car for half a season with out any issues. 2. I used the Anti lag launch function at a couple of races mid way through the season. 3. Next race blown waste gates. I repaired the waste gates after I found the problem. unfortunately I raced at the Toledo Ohio Solo with low boost as a result. 4. New waste gates installed for Nationals, first day of Pro Solo ( using ALS ), resulted in low boost for second day. I finished third but maybe the Low boost helped more than hurt. 5. Turned ALS off for good after that and I have not had an issue since. Also the waste gate that had the most damage was the rear one. Yes, it is closest to the exhaust but it also has the most direct "straight" path from the exhaust. Haltech has a disclaimer on using the ALS they should ad "will destroy waste gates"  Also added more pictures for ABS, Diff brace and exhaust tip.
				__________________ CT 93' FD Last edited by cturbo28; 02-04-2012 at 09:39 AM. | |
|  02-04-2012, 09:15 AM | #32 |
| Sua Sponte Join Date: Feb 2008 Location: Killeen, TX
				Rep Power: 18  |
			It's def. the offseason!  I was extemely happy with the engine David built for me a few years ago.  Using ALS seals? Paint those ugly fenders
				__________________ Road Atlanta August 2011 NASA TT 1:33 http://www.youtube.com/watch?v=IFY00PAK_Ps Traqmate's video of my car from the 2011 UTCC at VIR http://www.youtube.com/watch?v=2Zcn6...layer_embedded Video of Yellow LS1 FD at NASA TT at VIR http://www.youtube.com/watch?v=e6k0lJkcwrM |
|  02-05-2012, 12:10 AM | #33 |
| RCC Loves Me Not You Join Date: Mar 2008 Location: Colorado Springs, CO
				Rep Power: 20  |
			What's with the exhaust tip?  Maybe I missed it. I'm SO glad you figured out the wastegate problem, because that means I won't have to run water to mine LOL! |
|  02-05-2012, 12:56 PM | #34 |
				Rep Power: 0  |
			The exhaust tip is adjustable, I can point it to the left, right or down.  I have a spring that hold it in place. Also you can see each hook for the three adjustment points.   The adjustment is to direct the exhaust away from the sound meter on the course. We have a 100 db limit and mine is anywhere from 92 to 98.5 dbs.
				__________________ CT 93' FD |
|  02-06-2012, 10:57 PM | #35 |
				Rep Power: 20  |
			Oh OK gotcha.  I figured it was so you could point it but I couldn't think of why.  Makes sense haha.  I'm surprised they let you do that, I figured they'd have a cow about that.
|  02-07-2012, 09:51 AM | #36 | |
| Hi Join Date: Jan 2009
 Thanks again for sharing so much of your build. Good luck with the continued project. -ryan | |
|  02-07-2012, 09:39 PM | #37 | |
				__________________ CT 93' FD Last edited by cturbo28; 02-08-2012 at 08:49 AM. | |
|  02-21-2012, 10:45 AM | #38 |
				Rep Power: 0  |
			I started making a new oil fill neck that I will ad a catch can to later for my vented PCV set up. Also I am trying to get ready to dyno this weekend.  I will try and update everything before my dyno tuning session. I also added a picture of my two helpers.
|  02-21-2012, 10:52 AM | #39 |
| My minds tellin' me no... Join Date: Feb 2008 Location: Murfreesboro, TN
				Rep Power: 22  |
			Love the welding jig Carter.
				__________________ 1976 Mazda Cosmo RX-5 1976 Mazda Cosmo RX-5 2003 Toyota Tundra TRD 2015 Toyota 4Runner SR5 |
|  02-27-2012, 02:46 PM | #40 |
				Rep Power: 0  |
			Some more pictures of the over flow tank set up and new DS2 coil mounts. I did ad a vent line to the rear turbo drain which feeds the other side of the tank.  I will let everyone know how this turns out in an Auto-X. Hopefully I can keep from spitting out half a qt. a run..... Slow progress but it is getting together slowly. I also tried to Dyno the car last Saturday but I will go again due to some boosting issues I had.
|  03-07-2012, 08:48 PM | #41 |
				Rep Power: 0  |
			The season starter will be held this weekend at Georgia Motorsports Park.  See link for information http://www.scca.com/events/index.cfm?eid=3594 I added some pictures of my weekend project. enjoy...
|  03-14-2012, 08:39 PM | #42 |
				Rep Power: 0  |
			The rx7 survived the weekend. I placed first in the season opener. Although I was a little rusty I still pulled out the win. Here are some pics of the car in action.
|  03-15-2012, 12:25 AM | #43 |
				Rep Power: 20  |
			Damn that's sexy.
|  03-15-2012, 06:55 AM | #44 |
				Rep Power: 22  |
			Great job Carter!  Car looks good as usual!
|  04-14-2012, 05:45 PM | #45 |
				Rep Power: 0  |
				New Projects
			I have started some new top secret projects moving some weight back and right. I am just now fitting everything up and seeing if things are going to fit all together. If anyone has any ideas or suggestions I would be glad to hear them as some times I over think things.  1. EPS SW20 Electric PS pump moved to passenger side with battery and ABS. 2. EWP Craig Davis electric water pump, hopefully this will be controlled via Haltech PWM output. 3. ALT relocation Relocate Alternator to clear up some space up top and since I will be loosing my water pump pulley I thought I needed to relocate it. I would love to move it to the passenger side but packaging is a big issue on that side since the turbo and everything else is located there. Also my new engine is on the bottom of the list. I pulled the new engine out and put the old motor back in after the Dyno results. I will update later on the outcome of the new motor set up when I hit the numbers I want.  The last race I did was on the old motor not the new one.
