Old 01-01-2012, 08:51 PM   #1
db86na
db86na's Avatar
db86na is on a distinguished road
having some cooling isues on my fc
how do u tell if the water pump went bad?. so im driving today and my coolant buzzer goes off so i pull over and fill it up and go to burp it but it just keeps overflowing out the fill neck and wont stop and what sounds to me is the water pump making a grinding noise
db86na is offline   Reply With Quote
Old 01-01-2012, 09:19 PM   #2
db86na
db86na's Avatar
it kinda seems like a bad bearing in the pump but when i turn by hand it feels good
Old 01-01-2012, 09:23 PM   #3
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
Could the thermostat be stuck shut?
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
Old 01-01-2012, 09:27 PM   #4
db86na
db86na's Avatar
would i still get heater if it was
Old 01-01-2012, 11:28 PM   #5
NoDOHC
NoDOHC's Avatar
Unfortunately, I think that your issue is far deeper than a thermostat (deeper in the engine I mean). I think that you are describing the textbook symptoms of blown coolant seals. The coolant seals typically last about 200,000 miles or 20 years and then they fail. This is usually triggered by an overheating event, but not always.
The coolant seals keep the coolant in the water jacket and out of the combustion chamber. Depending on where in the cycle they fail, the engine may only run on one rotor for a little while after startup until the second rotor has cleared the water out. In extreme cases you may hydrolock (although I have never seen this one).
Basically, coolant seal failure is closest to a head gasket failure on a piston engine.
Your options:
Cry - Won't help much, but you may feel better
Try bars-leak or something similar - this is not a permanent fix, but may buy you a couple thousand miles
Get a used engine and put it in - probably the easiest and least expensive
Buy some $150.00 coolant seals and rebuild the engine yourself - This will cost more than $150.00 and will take a long time for your first time, you could port it while you have it apart...
Get another engine with blown apex seals and make the two into one - I really don't recommend this, but I have seen this work at least twice.
Old 01-02-2012, 12:42 AM   #6
db86na
db86na's Avatar
it starts on both rotors and has no smoke or acting strange and it never overheated temp was 1/4 way up on the gauge but i didnt even notice the belt was a little loose at first tightend it up and started it and noise was gone but ill check it out more in the morning when engine is cold
Old 01-02-2012, 04:50 AM   #7
Start with the small, easy stuff and work your way "upwards"...
http://fc3spro.com/TECH/PROBLEMS/P1/...OT/coolant.htm
If the thermostat is stuck, check the core of the radiator with your hand CAREFULLY.
The core of the radiator should be evenly hot when the thermostat opens.
If the bottom of the radiator (by the lower radiator hose) isn't as hot at the top (by the upper radiator hose) this is a possible sign the thermostat is bad.
The above also would indicate a blockage in the radiator core and / or something wrong with the water pump.
Easy test to see if the thermostat is working or not - throw it in a pot of boiling water.
Old 01-03-2012, 03:31 PM   #8
db86na
db86na's Avatar
did some work today on the fc pulled water pump apart and found a nasty thermostat and also my nasty water pump, im hoping this was my grinding problem and has a bad bearing it was so hard to turn the blades at first then it spun freely
Old 01-03-2012, 03:37 PM   #9
I don't like the color of the coolant...
Hope you're going to flush the system very thoroughly...
Old 01-03-2012, 04:01 PM   #10
db86na
db86na's Avatar
oh yes i am gonna replace thermostat and water pump and do a full coolant flush, can i just use some 1211 for a water pump gasket, and when i turn the timming pully by hand i dont have any grinding or any weird noises but the pump feels a bit sloppy that has to be my problem
Old 01-03-2012, 09:27 PM   #11
Raksj04
I have Ultra power in me.
Raksj04's Avatar
Is that from rust in the system???
Old 01-03-2012, 09:34 PM   #12
db86na
db86na's Avatar
yes sir this thing has been sitting in a feild since 1996 up intell 4 months ago and the owner i got it from never flushed anything now i have to deal with the problems
Old 01-03-2012, 10:15 PM   #13
Raksj04
Raksj04's Avatar
If your blower motor vibrates on the highest setting $10 says its a dead mouse or other rodent like animal.
Old 01-03-2012, 10:21 PM   #14
db86na
db86na's Avatar
well there was a ton of mouse terds under the interior when i pulled to paint it but back to the question has any one had a bearing go out in there water pumps and makes a grinding noise
Old 01-04-2012, 04:37 AM   #15
The water pump tends to puke it's seal and leak through the weep hole before it gets to kill the bearing...
With the fact that the car was sitting around for so long, it's no surprise the water pump bearing is toast.
"1211"?
Dunno what that is...
