Old 09-23-2011, 10:26 AM   #136
cewrx7r1
The Judge
My Triumph Daytona fast sensor is made a little different. The sensor is surrounded by a brass tube which is an extension of the brass base.
The brass tube has a few holes in it to allow a little flow of air through it.
This way the little expose sensor does not get the direct blast of air on it.
Unfortunately the place I got mine, no longer carries it. And when I search for it, I can not find it. Part # is T1900510 while dudemaaan's is # T1290510.
Got it from:
http://speedsupplies.com/partslistin...00&category=TM
Old 09-23-2011, 07:17 PM   #137
RICE RACING
Don Mega
RICE RACING's Avatar
Got it from:
Sounds like it would be much more durable
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 11-17-2011, 02:41 PM   #138
dudemaaan
dudemaaan's Avatar
wannaspeed.com has a few more of the sensors in
Old 11-21-2011, 10:54 PM   #139
yzf-r1
Banned
yzf-r1 is on a distinguished road
I've had no issues with quality or durability of the wannaspeed sensor in my car, but it doesn't respond as fast as I thought it would - still better than stock, so I guess that's what matters
yzf-r1 is offline   Reply With Quote
Old 11-22-2011, 02:04 AM   #140
dudemaaan
dudemaaan's Avatar
The sensor responds pretty much immediately. If you aren't seeing quick changes in air temperature readings it's probably because the air temperature isn't changing rapidly, at least from where the sensor is reading it. In my bench testing just breathing hot air on it caused rapid changes in resistance. You might also make sure the sensor is clocked properly so the air flows through the plastic square area rather then into it. Not sure if it makes a huge difference or not but maybe.
Old 12-27-2011, 08:09 PM   #141
FC3SDrift
FC3SDrift is on a distinguished road
mazda used an open element iat's on the second gen rx7's
FC3SDrift is offline   Reply With Quote
Old 01-11-2012, 04:58 PM   #142
cewrx7r1
The Judge
On some other 13Bs powered cars, Mazda placed the AIT sensor in the throttle body elbow where it would not heat soak.
Mazda is inconsistant!
Old 01-13-2012, 07:02 AM   #143
Signal 2
Viable Fossil
Signal 2's Avatar
As to durability, I've had my wannaspeed sensor now for about 30,000 miles. Relocated pre-throttle-body. That's close to 50,000 kilometers. Still functions as new.
I know two others who've had the sensor for a few years. No reported issues.
Jim
VR R1 FD
Old 01-26-2012, 10:19 AM   #144
RX SE7EN
RX SE7EN is on a distinguished road
What size are the threads on this? 1/8 npt?
RX SE7EN is offline   Reply With Quote
Old 01-26-2012, 06:25 PM   #145
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
I know this might not answer your question, but they are exactly, the same size, and thread as the OEM sensors... Making them a drop in fit...
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 01-27-2012, 09:38 AM   #146
RX SE7EN
I have a custom manifold that doesn't have a port yet, so I'm trying to figure out which bung to weld on.
Old 01-30-2012, 07:40 AM   #147
Signal 2
Viable Fossil
Signal 2's Avatar
Not sure what your set-up is, but some of us re-located it from the stock manifold to post IC/pre-throttle-body. Less heatsoak.
As for what thread size, just take it to a hardware store that carries metric and find a nut that will work. It's metric, but not pipe thread.
If I get a chance to get down to my shop I'll try to find my old OEM IAT and see what size it is...
Jim
VR R1 FD
Old 04-14-2012, 07:08 AM   #148
general7
general7 is on a distinguished road
Thread size is M10 x1,25 if my mind serves right
general7 is offline   Reply With Quote
Old 05-09-2012, 10:23 AM   #149
RobbieRX-7
RobbieRX-7 is on a distinguished road
Originally Posted by dudemaaan View Post
The sensors can be ordered from my site. Wannaspeed.com.
Can you link me up please? I've had a quick look but couldn't find it under sensors/switches.
Thanks
RobbieRX-7 is offline   Reply With Quote
Old 08-25-2012, 06:44 AM   #150
RIZZXX7
DIGG7ER
RIZZXX7's Avatar
RIZZXX7 is on a distinguished road
I just tried to order this and they're currently out of stock since the supplier stopped supplying the sensor
EXCELLENCE IS NEVER AN ACCIDENT, IT IS ALWAYS THE RESULT OF HIGH INTENTION, SINCERE EFFORT, INTELLIGENT DIRECTION, SKILLFUL EXECUTION AND THE VISION TO SEE OBSTACLES AS OPPORTUNITY...
RIZZXX7 is offline   Reply With Quote
