Old 04-13-2008, 05:22 PM   #1
AHarada
Removing the oil filler neck?
I'm removing the rats nest to get to secondary fuel rail where there's a leak. I'd prefer to remove the rats nest as one unit, and there's a bolt that goes through the oil filler neck, through the vacuum chamber, and into the rats nest bracket. How do I get this bolt off? Seems impossible.
Old 04-13-2008, 06:34 PM   #2
a7xh7
a7xh7 is on a distinguished road
mine just unscrews.. i forget if i have to use a open/box wrench to get at it from the front or if a 1/4 drive socket can sneak through, just poke around for a while longer u will get it
"sevens_ix"
a7xh7 is offline   Reply With Quote
Old 04-13-2008, 10:28 PM   #3
AHarada
I can't get to the bolt from the Dr. side, and there's not enough room on the Alternator side. I was thinking I'd have to take the alternator off?
Old 04-16-2008, 10:08 AM   #4
Signal 2
Viable Fossil
Signal 2's Avatar
There is a second 10mm bolt in the filler neck just aft (firewall side) of the one your talking about. Loosen that one first until it's almost out. That should allow you to carefully flex the plastic filler neck up and away just enough to get a 1/4" drive shallow socket with an extension onto the 10mm bolt your talking about.
Jim
VR R1 FD
