Old 05-24-2011, 11:15 AM   #16
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
Thanks for the compliments!
http://www.youtube.com/watch?v=SQySJPEP0Rs first start
http://www.youtube.com/watch?v=JmHcbYk6EQQ video now running!
I made a video driving it around but it won't load onto youtube for some reason-
it runs and drives great i now have the intercooler pipping hooked up unlike in the video. I still have a few pretty major things to do like find a new rear as the final drive ratio isn't very good for 65mph on the highway top speed was around 80 but the engine was screaming, I think 3.90 rear is a little high i need to find a rear closer to 3.3- It also has more vibration at idle than i would like the rubber mounts i used aren't quite thick enough so should be a simple fix. It still needs glow plugs too i've been cold starting with a hair dryer
yes i do realize my hood is crazy I was bored and had extra spray paint and masking tape, it got out of hand luckily this is just the screw around stage i'm going to build a cowl and paint it
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 05-28-2011, 12:36 AM   #17
12arotary
12arotary's Avatar
http://www.youtube.com/watch?v=VSiqPDJIc4E On the road!
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 05-28-2011, 01:20 AM   #18
Monkman33
Still Building my FD
wow. not going to lie, that's pretty cool. i like the fact that its all still mazda. :-)
Old 05-30-2011, 09:46 AM   #19
This is great. I want to see it shred the tires with the diesel torque!!
Someone needs a windshield and dash cap
Old 05-30-2011, 10:05 AM   #20
12arotary
12arotary's Avatar
i'll fix the windshield when i have everything perfect so it doesn't get broken by the engine lift again haha
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 06-01-2011, 05:02 PM   #21
Pele
Pele is on a distinguished road
Interesting...
How's the acceleration and how's the weight of the Perkins compare to the 12A?
Considering a swap into a 2nd gen.
Pele is offline   Reply With Quote
Old 06-01-2011, 07:00 PM   #22
12arotary
12arotary's Avatar
Originally Posted by Pele View Post
Interesting...
acceleration is pretty good surprisingly and pulls a lot harder than the 12a did at a much lower rpm, i'm going to swap rear's to a 3.27 from the 3.90 to make it better on the highway, which will slow it down too. it enters boost at around 2k so right where i want it- I never weighed the engine its self but if i had to guess id say it was a good 100lbs heavier including the turbo, the suspension stayed level and you really don't feel the extra weight I like it though it feels like it should have come in this car in the first place which is always a good thing
plus if i didn't mention before, first 100 miles clocked in at 47mpg
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 06-02-2011, 07:43 AM   #23
Pele
Excellent... Looking at a later model Ranger's 2.3L Mitsubishi 4D55 engine coupled to a Turbo II transmission and running gear.
Old 10-18-2011, 02:30 PM   #24
12arotary
12arotary's Avatar
A little update-
After a small mishap with the turbo return line getting clogged and blowing out the rear oil seal I picked up a new s4 turbo, corrected the problem and have driven it a few hundred miles since. Unfortunately I just don't like it. Strait line acceleration is the only descent thing about it. The gear ratio is all wrong. Turning feels awful since the engine sits way to high and due to the stock oil pan it can't go any lower without major mods. Without a new injection pump, injectors, and a basic engine overhaul (head gasket, valve seat, new springs) I'm pretty much at the max boost and fuel i can run. The engine just isn't worth the time and effort because the gains won't be that much more and there are better options out there already. That's where i'm starting over selecting my engine.
I figure i'll sell the whole set up and go with something from the mercedes line
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 10-19-2011, 08:54 PM   #25
jecr
jecr's Avatar
jecr is on a distinguished road
Originally Posted by 12arotary View Post
A little update-
Is it the handling your not happy with? Keep in mind a diesel engine is going to be a whole lot heavier which probably make the car understeer quite a bit. I bet a Mercedes diesel will be heavier.
93 VR RX-7 (277rwhp @10psi)
86 Diesel (Isuzu) powered RX-7
jecr is offline   Reply With Quote
Old 10-26-2011, 01:28 PM   #26
12arotary
12arotary's Avatar
i expected sub-par handling but its way worse than it should be because the engine just sits to high. If i was to go dry sump it would drop 10 inches and because of the iron head it is extra top heavy.
probably just going back to rotary though and diesel swapping something else
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 10-26-2011, 07:23 PM   #27
Raksj04
I have Ultra power in me.
Raksj04's Avatar
I bet it would be better with a VW TDI engine.
Old 10-26-2011, 09:55 PM   #28
jecr
jecr's Avatar
12arotary are you in the union, ky area.
Old 10-27-2011, 12:26 AM   #29
12arotary
12arotary's Avatar
tdi would make a great engine to swap but it's out of my price range.
jecr, north of dayton ohio
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 12-11-2011, 10:08 AM   #30
so any updates with this?
