Old 08-06-2011, 09:54 AM   #1
ppritchard
ppritchard's Avatar
ppritchard is on a distinguished road
Radiator Fan Replacement?
Searched, but not one thread on radiator fans?
Anyway, we have the drivers' side dead and a new one on the way from Ray.
The manual only details removing the entire radiator with fans attached.
Rather not do that. I've heard that we can remove the top in-the-way stuff and just disconnect the fan shroud, fans and wiring -- but again the manual just doesn't describe it that way.
Anyone removed the shroud and fans and left the radiator?
Any tricks or issues? Looks like up to four bolts holding the shroud.
Thanks in advance for any input.
ppritchard is offline   Reply With Quote
Old 08-06-2011, 08:49 PM   #2
Garfinkles Motor Works
Yes I did that last summer,replaced both motors .The motor was a direct replacement from Advanced Auto parts .Cheeper than the Mazda part and the same maker .The four bladed fan puts out more air then the five blade .I bought my second four blade fan from Mazda for about $34 .
Old 08-07-2011, 09:15 PM   #3
vincentrx7
20b FD
vincentrx7's Avatar
vincentrx7 is on a distinguished road
I went with a JEGS fan. I had to make a few mods but it moves much more air and is a lot lower profile.
Bobby
'93 20b RX-7
vincentrx7 is offline   Reply With Quote
Old 08-08-2011, 11:10 AM   #4
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
You can pull the fan's out through the top, you can even replace your radiator that way. I did it that way 5/6 yrs ago. Just remove everything you see that covers the fans. Airbox, IC, battery box from there you should be able to figure it out.
Old 08-08-2011, 03:15 PM   #5
ppritchard
ppritchard's Avatar
Thanks.
Fan Motor arrived today.
Hopefully that will be the answer.
thanks
Old 08-08-2011, 11:07 PM   #6
yzf-r1
Banned
yzf-r1 is on a distinguished road
Which one did you go with? A lower profile fan would be a big help to clear my IC duct
yzf-r1 is offline   Reply With Quote
Old 08-09-2011, 04:54 AM   #7
Signal 2
Viable Fossil
Signal 2's Avatar
If you need something aftermarket for clearance issues that's one thing. But just because a fan has a higher CFM by it's manufacturer doesn't automatically mean it's more effective when installed. Decent ducting is important too. The stock fan assembly is tough to beat IMO.
Never had a problem with mine. Still the original one....knocking on wood.
Jim
VR R1 FD
Old 08-09-2011, 06:08 PM   #8
Force13b
cxxxx|::::::::::::>
Force13b's Avatar
Old 08-09-2011, 07:32 PM   #9
hades
what SMIC do you have?
This is going to tear
Old 08-09-2011, 08:14 PM   #10
vincentrx7
20b FD
vincentrx7's Avatar
I don't know the model number but it was the one closest in size to the stock unit.
BTW, why is the stock unit have one a 4 blade and one 5 blade fan?
Bobby
'93 20b RX-7
Old 08-09-2011, 08:21 PM   #11
vincentrx7
20b FD
vincentrx7's Avatar
Are you just looking for a point of argument? Not sure why you point out the obvious? But for argument's sake, the JEGS fan fit nicely...as good as the stock with a few modifications. The rubber seals completely to the radiator on all 4 sides. I also have ducting made from aluminum sheeting to the radiator.
The low profile allows now for a custom cold air intake to the scoop in the hood.
Bobby
'93 20b RX-7
Old 08-09-2011, 11:38 PM   #12
yzf-r1
Banned
M2 Medium
Old 08-10-2011, 02:27 AM   #13
The five blade and four blade fans are used so then fans will not set up harmonic noise.Two four blade or two five blade fans near each other running at near the same speed will set up a harmonic pulseing noise .I use two four bladed fans and I have heard the pulse a few times with the hood open but it is not enough worry about .
Old 08-10-2011, 08:16 AM   #14
Like Garfinkle, I run 2 x 4 blade fans on my FD. Mainly because I no longer have the SMIC.. I was also told by some MIT engineer that 4 blades actually pull more air..
Old 08-12-2011, 09:56 AM   #15
Signal 2
Viable Fossil
Signal 2's Avatar
OK, let's argue. Apparently it isn't obvious. The OP posted a question about removing the fan assembly. Your reply to that is that you stuck a JEG'S fan in your car instead. As if that's an answer on how to replace the fan motor or remove the assembly. And without any qualifications as to "why" you went that route. The OP isn't exactly new to the FD and probably knew better. But for consideration to any readers who were new, I suggested that's not necessarily a good option.
I'm happy if it's working for you. But you posted no figures, pictures or reasons why getting a JEG'S fan was better. And I submit that in MOST cases, they are not.
Jim
VR R1 FD
