Old 07-15-2011, 07:36 PM   #1
Thumper
Backyard Mechanic
Thumper's Avatar
Thumper is on a distinguished road
Exclamation Took my oil pan off today and found this
I took off my oil pan to install an oil pan brace and I found this. Ive yet fully disassemble a rotary engine so I am at a loss on what it is , and it has me scared that I will need an early rebuild.
Thumper is offline   Reply With Quote
Old 07-15-2011, 08:29 PM   #2
FRED
FRED is on a distinguished road
Did you also find a small ball and spring to go with it?.
FRED is offline   Reply With Quote
Old 07-15-2011, 08:35 PM   #3
Thumper
Backyard Mechanic
Thumper's Avatar
No, but thats not to say that the ball and spring did not fall out last time i changed my oil. shouldnt there be a hole in it if it was the oil jet?
Old 07-15-2011, 09:25 PM   #4
That was my question too
Old 07-15-2011, 10:27 PM   #5
Thumper
Backyard Mechanic
Thumper's Avatar
This doesnt look like the pics of oil jets Ive seen
Old 07-15-2011, 10:30 PM   #6
Looks like some of the actual oil jets that I've seen though. Not to mention there's nothing else in the engine that looks like that unless something fell down the oil fill.
Old 07-15-2011, 10:43 PM   #7
It does look like an oil jet set screw...from the eccentric shaft?
Does it have a hole in the center of it?
Old 07-15-2011, 10:44 PM   #8
Thumper
Backyard Mechanic
Thumper's Avatar
shoudnt there be a hole in it? or is it just microscopic.
Old 07-16-2011, 12:15 AM   #9
Thumper
Backyard Mechanic
Thumper's Avatar
Well I am pretty sure that it is the oil pump lock screw, but what is its purpose? Can i just take off the front cover to replace it?
Old 07-16-2011, 07:42 AM   #10
Yes, there should be a little hole in it. No hole, not a jet.
Forgot about that oil pump screw..... how would that back out unless it was installed improperly?
And is it infact that?
Old 07-16-2011, 07:58 AM   #11
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
If it's a jet from the e shaft you'll have to pull the whole engine apart anyway. Might as well start by just removing the front cover and inspect the oil pump. If you don't find anything there keep moving on with the tear down. Good old exploratory surgery......
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 07-16-2011, 08:31 AM   #12
Thumper
Backyard Mechanic
Thumper's Avatar
Im not sure if it is or not. It will be a little while until I will be able to remove the front cover, but I will let you know when I find out.
Yea, thats what Ill do
Old 07-17-2011, 01:43 PM   #13
Dannobre
Dannobre is on a distinguished road
Isn't that the retaining screw from the stat gear bearing? Or is there one on that engine? Dunno??
Dannobre is offline   Reply With Quote
Old 07-17-2011, 09:30 PM   #14
FC Zach
FC Zach's Avatar
I was wondering the same thing.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 07-18-2011, 06:23 PM   #15
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
I would do the exploratory surgery as well.
Take engine out, take front cover off, inspect things under there.
Then if not any problems found there its rebuild time. The least you'll need is new coolant seals.
But I wonder how the hell does an oil jet from the e-shaft even make its way to the oil pan?
Makes me think its got to be from something under the front cover.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
