Garfinkle's Motor Works garfinklemw@gmail.com (TN) Custom products for 3rd Gen RX-7's |
#61 |
Rep Power: 17 ![]() |
Just found out my wife got the bracket in the mail this past Friday! Thanks again Garfinkle!
#62 |
You are welcome stay safe
#63 |
David
Received mine today thank you... where can i get some of those drop in anchors. and what size and pitch are they.... Thanks again |
#64 |
Most auto parts stores .They are called Jack Nuts ,get 1/4 20 TPI .I can send you some if you need .
#65 |
Can anyone tell me which wires on the stock harness go to which connectors on the FC Coil? I didn't receive any instructions. Thanks
Andy |
#66 |
The wires on the black connector that was on the stock leading coil .Get two eyelets and cut the black connector off and put the eyelets on the wires and bolt down with star washers if you can find them .Easy as that. You are the first to ask. If you need more help feel free to call.
#67 |
Oh I apologize, I know about that. But the polarity doesn't matter and I can connect them to either terminal on the coil? I thought the two pins were different on the stock leading.
#68 |
The wire color that is common to each coil goes to positive and the wire with green goes to neg
Bookmarks |
Thread Tools | |
Display Modes | |
