Old 05-18-2011, 12:35 AM   #1
turboed13b
turboed13b is on a distinguished road
Led tail lights
Well on the journey to convert everything to led I started on my tails. So far I have three rings that will run on pwm so they will get brighter once the brakes are hit.
This is the prototype I made using some generic led rings.
I then made an array with lumileds because the generic leds are not bright enough.
Generic on the sides and the lumiled in the middle.
Thats all I have so far what do you guys think?
turboed13b is offline   Reply With Quote
Old 05-18-2011, 06:59 AM   #2
project86
Can't.Make.Up.My.Mind.
project86's Avatar
where did you get the rings???
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 05-18-2011, 07:52 AM   #3
My5ABaby
My5ABaby's Avatar
I would just make sure the underrun the Lumileds and keep them voltage regulated. Although Lumileds are quality and very hardy, they will be run in a constant on state when the running lights are on and for extended periods at stop lights which can build up heat if they're pushed too far. I presume they're the 70mA ones. I would suggest running them at 50mA with a 12v regulator.
Also, AZDave at hidplanet.com sells a PWM setup that includes a voltage regulator. It's cheap and does everything you need.
Community Service Manual
RotorWiki
Old 05-18-2011, 03:40 PM   #4
project86
project86's Avatar
id like to do something similar with my s5 lights but i want the outer ring to be bigger and the leds to be closer together. Ive been thinking of getting piranha 4in round lights but they are really expensive
'90 GTUs
'10 Toyota Prius
Old 05-18-2011, 04:09 PM   #5
My5ABaby
My5ABaby's Avatar
There is nothing cheap about doing a proper LED setup. The Lumileds and Cree P4 I used were something like $.30/each. I used approximately 500 of them for both sides. Include the boards, wiring, resistors, PWMs, regulators, and any other incidentals and you're looking at $300+. This is of course an S4 setup where I used an extreme amount of LEDs, but it is still not cheap regardless.
I would also not suggest skimping on cheap LEDs for tailights. Cheap LEDs don't hold up to heat nearly as well and in a taillight application where you might be standing on the brakes at a stop light for a couple minutes, heat is an issue. LEDs may last 10,000 hours in perfect conditions, but add heat in and that drops dramatically quickly. On top of that, heat causes a shift in the color spectrum that is usually less than desirable. In addition, I doubt a cheap pre-made ring is conservatively run because the need to up the amperage for increased luminosity from cheap LEDs. For the Lumileds that are rated at 70mA and you run at 50mA for a nice bright light, it's no problem. However, a cheap 50mA run at 70mA isn't going to be happy. Now for interior LEDs such as dome lights, I wouldn't have any issue using the crappy chinese LEDs on ebay. Even if their life expectancy is cut to 50 hours due to overrunning and being cheap, that's probably 20x the amount you'd ever use your dome lights.
RotorWiki
Old 05-18-2011, 04:54 PM   #6
turboed13b
The cheap generic rings I bought off of superbrightleds but I am not using them for my tails they were just for prototyping they lack intensity and most likely will burn out quickly.
I made the ring of lumileds it took me forever to make them in a perfect circle since the shape of the leds are square it was kinda like a puzzle lol. I'm not sure if it is possible to stuff more leds into the circle because of the shape of the leds.
I am also using the optidrive kit from azdave.
Old 05-18-2011, 09:47 PM   #7
My5ABaby
My5ABaby's Avatar
If you use a PCB then it may be hard to position them as you want. If you make your own board from scratch then you can position them any way you want.
RotorWiki
Old 05-19-2011, 12:13 AM   #8
mazdadude7
mazdadude7's Avatar
mazdadude7 is on a distinguished road
loving the s4 led tails man. get that radio in?
mazdadude7 is offline   Reply With Quote
Old 05-19-2011, 09:55 AM   #9
My5ABaby
My5ABaby's Avatar
Sure did. I just need to find the plastic surround for the headunit and it'll be complete.
RotorWiki
Old 05-19-2011, 01:21 PM   #10
turboed13b
Here is one side done i have to turn down the brightness some so it doesn't look i'm braking all the time.
Old 05-19-2011, 01:40 PM   #11
My5ABaby
My5ABaby's Avatar
Those look good. Mine are, apparently, blindingly bright. I have 240 red/orange Lumileds running at 50mA so it's a bit much when I brake. Thankfully the PWM lets me turn them down when in running light mode as you're talking about. My plan is to tint my tails and actually have visible brake lights when doing so. There's not much I hate more than tinted stock tails that I can't see in the daytime because someone is a jackass.
RotorWiki
Old 05-24-2011, 02:49 PM   #12
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
those look great you should do my fb tails now
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 06-23-2011, 01:01 AM   #13
turboed13b
Finally got my lights done here it is finished.
Old 07-07-2011, 08:04 PM   #14
EresCuloFace
EresCuloFace is on a distinguished road
i love the s4 lights. has anybody made some for the s5?
EresCuloFace is offline   Reply With Quote
Old 10-12-2011, 05:44 AM   #15
DriFD3S
DriFD3S's Avatar
DriFD3S is on a distinguished road
Those look better than ANY aftermarket tail light I have EVER seen, EVER.
Good Job Man!!!
Live the DriFD3S or die trying.
JDM True Story.
the Vacuum line, to my MAP became detached while I was legally drifting.
my engine would not rev past 2500, and idled from 300-650 and was stalling.
Fortunately, I acquired a Zip-Tie.
I fixed a catastrophic engine failure, With a Zip-Tie.
JDM FTW.
DriFD3S is offline   Reply With Quote
