Old 05-12-2011, 03:42 PM   #1
Aees
Aees is on a distinguished road
Oil catch can
I`m gonna install a oil catch can and dont know where to install it.
Does anyone have pictures of where they installed it and where you bought it? I really dont want a flashy catch can that stands out...
Aees is offline   Reply With Quote
Old 05-12-2011, 09:29 PM   #2
NoDOHC
NoDOHC's Avatar
What is the reason for this catch can? Does your engine blow oil out of the breather on the factory canister? I saw a rotary do that once and it had a bad oil seal.
They are available for the FD:
http://rotarycarclub.com/rotary_foru...ead.php?t=5727
Unfortunately I can't help you further, as I have not had need or use for an oil catch can on a rotary yet.
Old 05-12-2011, 10:26 PM   #3
FC Zach
FC Zach's Avatar
I purchased a small can for my transmission. It's a can designed for racing go karts, so it's small and lightweight.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 05-13-2011, 06:08 AM   #4
Aees
I broke my purge controll valve, so I`m gonna replace it with a catch can.
In the progress of removing the rats nest.
Since I broke it I have capped the nipple on the UIM and the line going into one of the solenoids and just had a vacuum hose from the oil filler neck to the bottom of the car. Never seen any oil coming out from the hose, but i guess it`s better to have a catch can, so I can see if some oil have left the crackcase which would indicate a sealing problem right?
Old 05-13-2011, 08:16 AM   #5
88turboii
destroy, rebuild, repeat
88turboii's Avatar
catch cans are dumb. just route it back to the intake somewhere upstream from the turbo
Old 05-13-2011, 01:50 PM   #6
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
My install....
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 05-13-2011, 02:24 PM   #7
My5ABaby
My5ABaby's Avatar
I took that nipple and ran a vacuum hose to my transmission brace and just let it vent under my car...
Community Service Manual
RotorWiki
Old 05-13-2011, 02:56 PM   #8
Aees
Thanks for posting pics!
I can`t mount it there because of IC piping though.
This is the ebay can right?
Is the blue hose going from besides the battery tray the same hose that connects to ur turbo inlet?
Old 05-13-2011, 10:48 PM   #9
Boosted FC
Boosted FC's Avatar
Yes, I had to connect another piece of hose to that blue hose as it was not long enough. I will be replacing it with one complete piece shortly. It is the Godspeed CC that I got from Amazon.
Old 05-14-2011, 01:53 AM   #10
Prodigy
Half bubble off plumb
Prodigy's Avatar
Prodigy will become famous soon enough
so the purpose of a catch tank is to "filter" out all the condensation that occurs form running an engine hot then cold, hot then cold... or did I miss something... I have never understood why to have one... I remember hearing it will keep the oil out of the intake... but not sure at all about their function... and I'm not afraid to ask...
What do oil catch tanks do, other then 'catch oil in a tank'
J.
Originally Posted by Narfle View Post
The FD is like automotive heroin, You will either chase the dragon for the rest of your life, or find Jesus and swear them off forever
There is no limit to my stubborness...... just ask any of my ex's
"The most respected cars in history are the ones which stick to their guns, do things differently and make no apologies for it."
360 gamertag: Tichlis
Prodigy is offline   Reply With Quote
Old 05-14-2011, 09:13 AM   #11
Aees
I guess it`s because of if you are having a sealing problem and pressurize ur cranckcase the pressure will vent out. If you are using a catch can, or the original purge controll valve ---> Intake manifold is up to you. The reason why I will use a catch can is because then I can see in the can if I am having a sealing problem or not.
