Old 05-05-2011, 07:34 PM   #31
NoDOHC
NoDOHC's Avatar
Originally Posted by My5ABaby
So why did Mazda even make a 6 port?
If you look at my mileage numbers above you will see that they were better on gas. They also would probably make better low-end torque if that awful mess of an upper intake manifold were to be replaced with a decent aftermarket one and some ITBs.
Some day I intend to build a max-effort 6-port with a custom upper intake manifold. I saved 2 sets of irons to practice with for the porting (filling the top of the aux ports will probably prove to be the most difficult part).
Old 05-05-2011, 11:26 PM   #32
Originally Posted by My5ABaby View Post
From what it appears at least on the above dyno, the 4port basically only makes less torque than the 6 port at idle. If it's around 1k that they equalize it's pretty much the second the gas pedal gets looked at...
Be careful of the comparison...
The 4-port was using a "heavily modified intake setup" - that's already a big advantage.
Most of us know the stock intake manifolds are pretty restrictive.
Old 05-06-2011, 07:58 AM   #33
My5ABaby
My5ABaby's Avatar
Ah, missed that part.
Community Service Manual
RotorWiki
Old 05-06-2011, 11:50 PM   #34
NoDOHC
NoDOHC's Avatar
I apologize that I don't have numbers for a stock 4-port, I have one right now (slated for a friend), but it is too much work to put it in the car (and I don't want to give up the power). I do know a guy who put down 185 WHp @ 7200 rpm and 145 Wlb-ft @ 5100 rpm on a carb'd 4-port (with completely stock ports on a Mustang dyno). However he was not running a stock intake manifold either.
The comparison is not very fair, but the 6-port did have 9.4:1 rotors while the 4-port was running 8.2:1. They had similar tunes (same ECU). I would love to see some dyno curves from built 6-ports.
I have one from a friend with fully ported 6-port, custom intake w/ ITBs, MicroTech EMS and stock ignition. I can't scan the curve right now, but it made 142 WLb-Ft @ 6600 rpm and 195 WHp @ 8400 rpm (Dyna-pack dyno).
