Old 03-26-2008, 06:23 AM   #31
My5ABaby
My5ABaby's Avatar
You don't HAVE to replace any bushing or that bullshit to replace the struts. Its not a big deal. Look on eBay or some other sites. You can pick up a set of factory struts with springs for under $40 sometimes. A few bolts at the bottom, a few nuts at the top, and you're done. I do however fully recommend an alignment afterwards though.
I'm thinking of springing (hehehe) for some new ones. I can pick up HP's for about $250 or AGX's for about $350. That's pushing my budget, but if I get them I won't have to get new ones again.
Ugh, decisions, decisions.
Originally Posted by $100T2 View Post
Ugh. All you did now is open it to new rust. You definitely need to replace them.
As far as the bushings go, no, they won't make your ride noticably more bouncy or stiff. You'll notice the car will stick better in the corners, but it won't jar you around that much.
Switch to coilovers and lower it like my 'vert, then you will scramble your brain. Just the bushings? No biggie.
Heh, I wrote them off so the new rust doesn't matter much. Thanks for the info about the bushings though.
Old 04-05-2008, 08:24 PM   #32
My5ABaby
My5ABaby's Avatar
Quick update. Got one of the fronts off (had to get mounts so I left the other on for now) and I decided to share the rust filled glory.
Is it supposed to spread like that in the middle of the mounting bracket?
And yes, the hammer was used. Often...
Old 04-05-2008, 08:25 PM   #33
My5ABaby
My5ABaby's Avatar
My suggestion... if you still have the stock suspension on, give it a nice good look over.
