Old 04-22-2011, 01:40 AM   #1
JustJeff
JustJeff's Avatar
Lets talk about FD oil pressure regulators
I'm considering doing an FD oil pressure regulator with my s5 13B turbo rebuild. FSM for FC and FD oil pressure:
FC
regulator relief = 71psi
For testing at 3000rpm = 64-78psi
FD
regulator relief = 110psi
For testing at 3000rpm all the FSM says is 51psi (min.)
Is there a downside to increasing oil pressure? Racing Beat in their tech section warns that using their race pressure regulator set 105-115psi will increase oil pump wear. Is this a real concern? Is the extra wear on the oil pump worth the benefit of increased oil pressure?
If I'm increasing oil pressure will the OEM oil cooler still cool as much as needed? Will oil temps rise? I've learned from watercooling my computer that too much pressure/flow can be a bad thing for cooling if the liquid does not stay in the radiator long enough to remove it's heat.
Old 04-22-2011, 05:08 AM   #2
I've never had good luck doing that mod.
The engines would end up smoking more.
Any reason why you're looking at this option?
Only real reason to increase oil pressure is to increased redline on the engine, or if you're running serious amounts of power - i.e. over 400hp?
Other than that, there's no real reason to do this on a daily driven street vehicle.
The Racing Beat 85psi(?) street OPR upgrade is good enough for most applications.
It's reasonably priced too.
Old 04-22-2011, 07:21 AM   #3
My5ABaby
My5ABaby's Avatar
So for example, on a stock block TII with a BNR stage 2 (and supporting mods of course) that puts down around 300rwhp, would the Racing Beat OPR be an upgrade or just wasted money?
Community Service Manual
RotorWiki
Old 04-22-2011, 07:29 AM   #4
Buggy
I've been Wankeled!
Buggy's Avatar
Buggy is on a distinguished road
I've done the FD regulator on my old FC and my Rx-4 engine. I've had no issues with either engine......
1976 Rx-4 hardtop. Half bridge 3B 13B, S5 NA rotors, Renesis e-shaft, stat gears, and bearings, balanced rotating assembly, RE dual weber 36 DCD's 203rwhp 137ft-lbs torque DGRR 2011 3rd place
1974 Rx-4 all original 27,000 miles
1988 Rx-7 TII 320rwhp. DGRR 2012 3rd place
Buggy is offline   Reply With Quote
Old 04-22-2011, 07:49 AM   #5
diabolical1
I have radioactive semen
i've used the REW rear regulator in two of my engines now, a 12A i built a few years ago and a 13B i just put together. there was no smoking on the 12A and i should be able to report on the 13B once it goes in the car and is fired.
Old 04-22-2011, 12:30 PM   #6
JustJeff
JustJeff's Avatar
I'm considering the FD OPR simply because it's a cheap mod to put on while the engine is apart. $34 for the FD that I'm told and have read is a 105psi OPR. The RB OPRs are all in the $100 range. Am I missing something that would justify RB charging almost 3x as much?
I'm running mostly stock S5 13B turbo. My mods are in my signature, that's alot easier than typing them out in threads. I'm looking more for reliability and longevity than added HP. If I can toss on some mods that are cost effective and won't affect driveability I'm interested. Somewhere down the road I may do a BNR or even find a core and start a new rebuild and have more fun with that engine.
Is the only benefit at high rpms when oil pressure tends to drop? Does the higher pressure equal to more flow, more cooling and more or better lubrication across the RPM range? Or is the only benefit to higher oil pressure at higher rpms?
See above:
RB OPRs are $100
FD OPR iss $34 and is a 105psi regulator
I'm always suspicious when you can get the same thing for less cash. Hopefully some people will chime in with experiences, knowledge, etc.
Originally Posted by yzf-r1
Old 04-22-2011, 07:27 PM   #7
Monkman33
Still Building my FD
How can you really wear the oil pump much more? it is always moving at an rpm dependent rate.
also, if the oem part will get you where you want to be, I'd go that route... especially when it comes to something critical like the oiling system. Oem parts have to take longevity into account.
Old 04-23-2011, 05:05 AM   #8
Yes, that's the most compelling argument for going with the stock FD OPR.
Most of my (customer) builds are in the middle of a rebuild, so the additional $60 for the RB "street" OPR isn't that much difference, considering that we're usually working with a ~$2,000 budget for the rest of the parts.
You want cheap?
How about shimming your original OPR?
http://www.aaroncake.net/rx-7/shimoil.htm
You can also "crush" your original OPR like in this video:
http://www.rebuildingrotaryengines.c..._Oil_Regulator
Higher oil pressure is for proper oil lubrication of the oil journal bearings.
Not enough oil pressure causes contact of the bearings, and we all know this is bad.
Increased load from the engine increases the requirement for oil pressure.
This usually means increased redline revs and / or increased power output.
Old 04-23-2011, 08:18 AM   #9
I run an FD OPR without shimming the relief valve in the front cover and I see a steady 100psi cruising down the highway @ 4k. I'll see 130-140 psi on cold startup. I would like it to be a little lower. I'm in the category or higher revs and higher torque though so while I need the pressure, I have too much. Then again, I felt that the stock Cosmo OPR was a little on the low side.
Don't forget though, that I modded my oil pump so my pressure is higher than most because of that o-ring in the pump.
My pressure also gets so high that I constantly blow out the front cover o-ring. I've tried gasket, no gasket, proper o-ring, bigger o-ring. Doesn't matter what I do, first oil-change after removing the front cover, I always... ALWAYS find the o-ring in the filter, yet I still get those pressures. I also cleaned and bored all the passageways in the front cover so I'm sure my pressure is dependant on a few of the mods that I've done.
Next time the oilpan is down, I plan on swapping OPRs.
Next engine I build, I plan on making the oil pressure adjustable externally, and bypassing the front cover all together, the original front cover outlet will actually become the return dump.
One of the reasons that I believe the REW OPR is set so high is becuase they are feeding 2 turbo's and need a slightly higher pressure to get more volume.
You want cheap?
REALLY?
Old 04-23-2011, 08:23 AM   #10
RICE RACING
Don Mega
RICE RACING's Avatar
DO IT!
Personally I have Never ever had a motor smoke due to high oil pressure!.
Every engine I build uses the 13B-REW rear regulator. I do MANY T2 based engines for various customers.
The higher oil pressure is a must in anything really if you want to bearings to live, especially when you are making an honest 450bhp. Any decent motor even stock ported will see 8000rpm all day long (most see 8500rpm) and when you combine this with 500bhp, let alone more power! you will find out the hard way why this level of oil pressure is needed.
Oil pump wear is never a problem, though you do loose some power running higher oil pressure, which is nothing compared to how much you will be making when you are justifying running the higher pressure anyway.
DO IT!
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-23-2011, 12:53 PM   #11
Side note:
The stock FC turbo and FD runs basically the same oil pump - 17.5mm width rotor?
So I don't think accelerated oil pump wear should be an issue.
The oil pump is typically pumping out close to 150psi - 200psi of oil pressure in the front cover - i.e. right after the oil pump itself.
This is why there's another OPR in the front cover (which most people don't mention).
Old 04-23-2011, 01:48 PM   #12
Isn't that more of a relief valve to keep the pressure from spiking throughout the system? IIRC the regulator that most people toy with is at the end of the line, where it should be, but extremely high pressures, cold start for example, would overpressurize everything before the OPR in the rear iron had a chance to react?
Old 04-23-2011, 02:27 PM   #13
Technically, the rear OPR is a relief valve.
The front one is set around 150psi, IIRC?
It has to pump through the oil cooler (and lines), so that's why it's set so high?
Old 04-23-2011, 02:45 PM   #14
Yeah, you know what I mean Ones more of a relief, the other more of a regulator..... right???? Brian needs sleeeeeeepppppyyyyy
Old 04-23-2011, 02:55 PM   #15
diabolical1
your posts have actually now given me some insight now into why my pressures on that motor reacted with increased RPM appropriately, but started to fall off shortly afterwards. all this time i thought it was the modifications i made to the e-shaft jets. now i'm thinking i might have simply blown out the front cover o-ring.
if i recall, that front regulator bypasses at 156 psi from the factory, it usually gets shimmed when you use the high pressure rear regulators.
