Rotary Tech - General Rotary Engine related tech section.. Tech section for general Rotary Engine... This includes, building 12As, 13Bs, 20Bs, Renesis, etc... |
04-13-2011, 07:16 AM | #1 |
destroy, rebuild, repeat
wastegates and emap
this is probably a stupid question, but i have been reading up on emap (pre-turbo exhaust pressure) lately and got to thinking.. on an internal wg setup, what stops this from opening your wastegate before target boost is reached? i figured this is not a problem on external wg, because usually they open against the flow of exhaust, and/or they have dual ports so boost pressure works to keep the valve closed before target boost is reached
im running a 60-1/p-trim S5 hybrid with the stock 6psi wg actuator. but im running 15 psi, so the emap at that level has to be like 15psi minimum, right? why doesnt it push open the 6 psi wg door and let all the exhaust out?
1993 RX-7 Touring MB, stockport 13B-REW, 9.4CR rotors, T04S 60-1/p-trim single turbo 1986 RX-7 Base project track beast Last edited by 88turboii; 04-13-2011 at 07:58 AM.. |
04-13-2011, 08:23 AM | #2 |
Honestly, at 15 psi MAP it's probably closer to 30psi EMAP.
It's a function of a few things, the surface area on the actuator that's getting your 15 psi (pounds/SQUARE inch) is probably about twice that of your wastegate. The flow of exhaust out of the wastegate is not going to be enough to divert ALL the gases away from the turbine wheel.
04-13-2011, 04:22 PM | #3 |
Wastegate spring
-Ted |
