Old 03-12-2011, 07:08 PM   #1
RICE RACING
Don Mega
RICE RACING's Avatar
Maximum boost thread (93 oct > pump petrol/gasoline only!)
So poofters, this thread is a log of what boost you have run on pump gas
Post it up, some proof would be nice to weed out the homosexuals from the real men NO BDC styled youtube video's or rants allowed sorry! oh and your engine must be running and actually achieved something of note (acceleration times etc)
I'll start off. RRWEP110 Water Injected.
~30psi on pump petrol and water injected
www.riceracing.com.au
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-16-2011, 05:13 AM   #2
RICE RACING
Don Mega
So I am the ONLY ONE NOT LIKE BDC on this forum? FFS people post up something in these tech threads or I wont waste my time sharing
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-16-2011, 05:28 AM   #3
Mazdabater
FC3S
I would love to post something, but don't have a running car LOL
Old 03-16-2011, 05:45 AM   #4
RICE RACING
Don Mega
Does not stop BDC or HC from posting reams of shit lol.........
But all good, when you do get it going post up and share away
Hopefully some Americans will get behind this web site rather than posting on the poofter forum and make this section worth reading. Think of it like a forum without HC or BDC
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-16-2011, 07:44 AM   #5
I'll post when I have new numbers... nothing really impressive about 1B on stock REW twins......
I love the logs of data, I have plans to be on the dyno in 4 weeks so we'll get some logs, and runs, and vids up then.
Until then though, I'll just keep on following the thread.
Old 03-16-2011, 11:37 AM   #6
I post plenty in the tech sections (mostly Fabrication and a few others). But like everyone else, the car is under the knife.
Old 03-17-2011, 09:45 PM   #7
RICE RACING
Don Mega
To give this comparison test some context:
RICESP (stock std 13B-REW engine, full catalyst exhaust, T04 type turbo, plumb back waste gate, small standard inter cooler 1310kg)
*fully compliant genuine road car*
ND4SPD (Cosmo 13B, full bridge port, T51 type turbo charger, large front mounted inter cooler, gutted exhaust, open waste gate pipe 1250kg)
*quasi race car!*
I did some very interesting comparisons to ND4SPD (Mazda Capella I tuned with RRWEP110 WI) V's RICESP via the immense analysis power of the VBOX
I'll list up some comparison results: About the total FALLACY of " typical dyno sheets"! v's real world power and times taken for vehicles to actually do "work" with known levels of weight/mass!!!
This car makes on a dynohomodynamics ~390rwkw on 19psi boost (full bridge port & T51 turbo 1250kg as run at race track) where we got these recordings. You will see RICESP at 1310kg run weight is just as powerful (real rwkw! power as measured by me via VBOX!) and its just as fast in peak power band too (what really matters at the end of the day rather than poofter dyno sheet comparisons)
This report is of ND4SPD in its peak power band (6000rpm to 8200rpm) = 110kph to 150kph in 3rd gear on 19psi boost (VBOX measure = ~310rwkw owner has sheets of 380 to 390rwkw on homo dynamics guess machine)
ND4SPD = 110kmh to 150kmh = 2.07 seconds
This report shows RICESP and the first one is a FC RX7 fitted with a bridge port 13B running 15psi boost and a GT35 turbo lol (you can see I am twice as fast as it lol 4.43 seconds V's 2.06 seconds!) This car apparently makes 270rwkw dynohomodynaimcs @ 16psi boost LOL! You can see these dyno figures are not worth pissing on in the REAL WORLD! and are vastly overstated from what the cars actually makes when you apply real physics to them!!!
And the other result table is at full boost when I tuned it (ND4SPD) on road just before setting national dyno record http://www.riceracing.com.au/water-injection.htm < *read customer testimonial* (which to this day still stands!) for the only ever 13B rotary to lay down 3 back to back power runs of this level and still be able to drive home on pump petrol
Boost, EGT, RPM, AFR sensors fitted in this tuning session.
RICESP = 110kmh to 150kmh = 2.06 seconds
My RX7 is pretty quick I think you will all agree and this is still not sharing the current state of high power tune *I'll save that for another day*
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-20-2011, 04:43 AM   #8
RICE RACING
Don Mega
So here is a report showing a mates drag car v RICESP
RICESP = 2.57 seconds (just in one gear, great show of power band)
Simon Ward = 2.64 & 2.69 seconds (high power at start of test, then less grunt shows up at higher speed, gear)
Drag car specs:
3.3lt Holden 202 (very old school set up!)
5 speed Lenco clutchless shift gearbox
1007kg car (1077kg as run in this test)
35psi boost (see logging)
Ran 6.75 @ 107mph 1/8th mile goat track in this VBOX file at night (won the event lol) *2 back to back runs*
RICESP: is the 2.48second 90-140 test std (3 gear acceleration test)
1310kg run weight Specs listed many times already!
Here is a pictures of the car. Bloke is a local legend, basically wins against all comers (I'm serious) has been running at that track for 30 years! Oh and his beast is water injected too
I helped him jet the carburetors and set the ignition timing on it till it got as fast as it would run Via the VBOX logging, this was done during the event and these final two runs are back to back from the evening finals (night runs interesting with no head lights and poor track lighting lol!@!! (have no mph boards at local Goat track! so VBOX is invaluable! Tim cards work but run faster at track due to roll out ghetto timing lights common to ALL Drag tracks, VBOX shows slower times (depends on how deep you stage!) always as its recording exact start & not guessing like light beam bullshit!) he was amazed with what "modern technology can do" BTW it has no wastegate so the boost is max it will run!!!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-21-2011, 06:11 AM   #9
RICE RACING
Don Mega
RX7 comparisons
This is another interesting comparison: From my collection of VBOX tests http://www.riceracing.com.au/vbox-ii...ing-tuning.htm
90kmh to 135kmh (best power gearing for the stock RX7) see rpm logging.
RICESP V Spirit R Type A (stock standard)
Car specs:
Spirit R Type A
1335kg as run
280PS factory rated engine (100% stock std no mods at all)
Car ran 0-100kmh in 5.55 seconds & 13.85 second @ 104.78mph RR V-BOX Recorded for 1/4 mile *no roll out*
Time = 5.06 seconds & 158 meters
RICESP:
~21psi Rice Racing Engineered Water Injected Monster
1310kg as run
Power is over double a factory RX7 (see actual VBOX RR rwkw measure) so roughly double the power, double the acceleration & half the time required to do it and distance as well
Time = 2.21 seconds & 69 meters
VBOX File report
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-24-2011, 09:15 PM   #10
RICE RACING
Don Mega
Exclamation Get On It POOFTERS :-oc==3
She has passed the 1.8kg/cm durability tests with flying colors & the performance is amazing. We have the new settings at 2.10kg/cm (over 2 bar gauge, 300kpa ABS, 30+psi in the old money)..... there is still plenty of margin left in the set up to run 2.5kg/cm in street trim but as before will run at the intermediate step to prove it rather than do a one off power pull BS type sheet posting as is the norm among most kiddies shops or internet experts
The acceleration is gag factor to the max! it's not scary but I tell you it does make your arsehole pulsate in mild fear if you have not sampled this kind of thing recently.......... !!!!!!!!!!!
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 04-26-2011, 05:25 PM   #11
project86
Can't.Make.Up.My.Mind.
project86's Avatar
im not at all familiar with tuning as i have never had the need or means tor try. but im getting the point here and its extremely impressive.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 03-03-2012, 09:47 PM   #12
RICE RACING
Don Mega
Bumpski!
2bar boost for a long time now.
Any other pretenders out there who have not blown up BDC or HC style on inferior meth injection yet LOL??????????????
Beuller ???????
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-03-2012, 09:49 PM   #13
RICE RACING
Don Mega
Carbon Wings
Originally Posted by sa22c View Post
RICE you are a mad ****
http://www.youtube.com/watch?v=sXYAJWAV7YY
This is great reference for you.
86mph the 638bhp ZR-1 pulls 0.44G Mine 0.570G
110mph 0.31G Mine 0.411G
ZR-1 = 3350lb as tested
RICESP = 2910lb as tested
Power peak for both cars in two different gear (you can guess the power of my car) it's somewhere around/near/over? 600bhp as remember at higher speeds aero dynamic loads play more effect than weight
http://www.youtube.com/watch?v=A-SW0H8smRc
100kmh to 200kmh
ZR-1 = about 7.2 seconds
RICESP = 6.2 seconds
Worlds best
Apex Seals
Coil on Plug
Water Injection
ECU Calibration
Old 03-16-2012, 05:37 AM   #14
PSI
PSI is on a distinguished road
220kpa or 31.9psi on pump gas with water only injection - 75mm turbo. Will save a log next time I have my lap top in the car.
No CDI ignition either.
PSI is offline   Reply With Quote
Old 03-16-2012, 07:54 PM   #15
This should be entertaining
What are you running for ignition?
