Old 03-02-2011, 10:41 AM   #16
JustJeff
JustJeff's Avatar
TTT- I'm using stock ECU...well Rtek but, you get the point. Before my engine goes back in I'm replacing any suspect areas.
Old 03-02-2011, 11:09 AM   #17
There's probably going to be more suspect area's than you think on a 25 year old harness. I've run into issues where the copper gets so brittle that I've broken it crimping butt connectors in, and then wrapping the entire chassis harness. Infact, hours before I was getting ready to leave on my epic road adventure, I noticed my front markers were out. Turned out to be a buttsplice that broke the wires and was only making intermittat contact. Pulled the bumper, fender and unwrapped most of the chassis harness hunting down that break. Sucked balls. Think of what might happen if that happens with say an injector on a boosted engine..... pop goes the rotary
Old 03-02-2011, 03:35 PM   #18
My5ABaby
My5ABaby's Avatar
N/A > Boooooost
Community Service Manual
RotorWiki
Old 03-02-2011, 03:40 PM   #19
Lies!
Old 03-02-2011, 04:36 PM   #20
Blasphmer!!!
Old 03-02-2011, 06:48 PM   #21
JustJeff
JustJeff's Avatar
Agreed. I'm going over everything. It's been an ongoing battle ever since I started tweeking things from having my swap done a few years ago. The guy who did my wiring for my TPS, to extend the N/A plugs to meet where the turbo wiring should meet.....well lets just say it was subpar. I'll post up pics for your shock and amusement later tonight.
Old 03-02-2011, 07:11 PM   #22
When it comes to wiring, very little shocks me anymore.... it just amuzes.... sorry it happened to you though.
Just makes me wonder how many mytery fails are due to poor wiring
Old 03-03-2011, 01:37 AM   #23
JustJeff
JustJeff's Avatar
This was what I found after I started having engine problems shortly after my swap. The fuzzy picture is a cheap speaker wire someone used as a patch. Not only was it the cheapest of wire you could imagine, but the copper was corroded from one end to the other. All the dark area inside the insulation and also on the center area of the crimp is corrosion. The wire was corroded enough that the corrosion bled thru the crimp. The wire spliced in looked like it sat in the bottom of a damp trunk for sometime BEFORE it was used.
The other problems I had with almost every crimp the person made was that they didn't trim the insulation back far enough on just about any of the crimps. I had a few crimps that came apart in my hands while trying to test and adjust my TPS.
This is my replacement of the bad TPS. I swapped some from an N/A bracket to a turbo bracket and went over all the splices with solder.
Old 03-03-2011, 05:36 PM   #24
JustJeff
JustJeff's Avatar
This is a little more on topic. I was trying to replace my water thermosensor plug on the back of the waterpump housing. I have what I thought were two spare S5 N/A harnesses to steal parts from. At first I thought this was a water thermosensor plug...but the notches are on the opposite side.
I'm thinking of taking a dremel to it and simply making a notch.
Old 03-06-2011, 03:25 PM   #25
JustJeff
JustJeff's Avatar
Can anyone help me with a description of these terminals/connectors? It's from a S5 Thermosensor plug. Rather than splice some old wires into my harness I'd prefer to get new connectors and use new wiring.
I'd also love to find a new thermosensor plug like the previous post. But I'm having trouble with what to put in my searches on Mouser and similar sites. It's rectangular, female, two position, green. If anyone can help with how to narrow my search I'd be very grateful.
Old 06-06-2019, 03:44 AM   #26
jerry51
jerry51 is on a distinguished road
try https://www.allicdata.com/products.html
they might have the connectors.
jerry51 is offline   Reply With Quote
Old 06-07-2019, 11:10 PM   #27
8 year resurrection! But for future reference...
https://www.bmotorsports.com/shop/in.../cPath/109_172
www.corsa-technic.com
http://www.easternbeaver.com/Main/El...onnectors.html
Corsa-Technic is the one I normally use. And if what you're looking for isn't on their site, you can contact them and they'll find it for you. They've done it for me once already.
Old 05-02-2020, 06:08 PM   #28
OHhhhhhhh Nice.
