Old 06-11-2010, 01:18 PM   #1
gada.hiren
gada.hiren is on a distinguished road
Question common problem and oil usage
Hi Friends
need your help. i am planning to buy a RX8, so from which year i should start my search i have read in few websites that from 2005 there were less engine failure. and also after how many kms i should change the oil and what oil i should use. one of my friend advised me to use mobil 1.
please help me out
gada.hiren is offline   Reply With Quote
Old 06-11-2010, 01:52 PM   #2
where are you from?
guessing not in USA as you are using KM?
By your question you are more interested in reliability.. so I say check your country's Mazda warranty and make sure the car in interest will give you some time for just in case situation.
Here I believe 8 year, 100K miles. So, Most 04 models will loose its warranty next year sometime.
Old 06-11-2010, 02:53 PM   #3
Originally Posted by gada.hiren View Post
Hi Friends
please help me out
I would actually start with a 2006-2007. Most issues were resolved by then, and they are most likely to have the most up to date TSB's and recalls.
I am not going to convert, but I change my oil every 3000 miles, checking it every 800 miles to see if it needs a top off.
I use standard Castrol 20w50. Of course, it gets very hot in the summers where I am. Just DO NOT use the factory recommended oil. It is too thin, and can cause bearing damage.
My 2004 has nearly 200,000 miles, 160,000 on the current engine.
Old 06-21-2010, 12:54 AM   #4
Mo04rx8
Mo04rx8 is on a distinguished road
What should I use on my 04 RX-8 if I only have 58k on it?
Mo04rx8 is offline   Reply With Quote
Old 06-21-2010, 06:51 AM   #5
Your engine is still under Mazda warranty, so use exactly what they tell you to. If you don't they will find a way to void it if it pops.
Sucks, but that is the reality.
Old 01-30-2011, 03:20 AM   #6
chaz255
chaz255 is on a distinguished road
i am picking up my rx8 in a week from Houston the previous owner used 20w-50 for the last 80k, I live in nw arkansas, for the summer that would work fine -- what would you guys recommend for winter. thanks
chaz255 is offline   Reply With Quote
Old 02-03-2011, 12:28 PM   #7
willnordacgreen1211
willnordacgreen1211 is on a distinguished road
i use 5w-30 for the past 35k miles. not one single hiccup..... yet.
willnordacgreen1211 is offline   Reply With Quote
Old 02-03-2011, 02:18 PM   #8
I used 20w50 in the summer, and 10w40 in the winter.
Who are you getting the RX-8 from?
Old 02-12-2011, 10:38 PM   #9
MazdaMike
S4 Owner
MazdaMike's Avatar
MazdaMike is on a distinguished road
I work for my local Mazda dealer and I can say I never put 5w20 in when I do an oil change, always 5w30. You shouldnt have a problem if your using thicker oil. I would recommend Castrol conventional oil.
1985 Mazda RX7 GSL 13B, Holley etc
1997 Mazda MX6 LS - DD lowered on 17s
MazdaMike is offline   Reply With Quote
