Old 02-03-2011, 07:45 AM   #46
N.RotaryTech
Home-brew Rotary
N.RotaryTech's Avatar
Haven't really yet driven this car to get a feel for its power & torque, I don't really expect much since its a mild ported S4 NA.
I did get the oil leak fixed, kind of, its still leaking a little where the other plug is in the oil filter pedestal. Probably just needs some sealant.
Updated Engine picture.
And how its going to look for now until the next cosmetic change.
I made a hood scoop block off plate. Its a little rough. I'm not using the scoop anyway, and this should keep most of the rain out.
Old 02-03-2011, 08:31 AM   #47
N.RotaryTech
Home-brew Rotary
Engine specs.
As of now. Nothing really special.
Its basically an S4 NA. 9.4 comp rotors, S4 intake manifolds.
Apex seals are RA Classics. Also has FD corner seal springs.
Porting: End plates have been street ported. Mild?
Housings have had the NA diffusers grinded out. And ports have been mildly ported.
Exhaust has RB mufflers and pre-silencer.
Clutch is a Clutch Masters stage 2.
Air filter is an Advanced Auto Parts store bought cone style.
Radiator is a no-name brand from an online discount parts store.
Lawn mower battery from walmart.
It still has all the original S5 electronics.
It has had the following components removed for various reasons.
Emissions equip. Rats nest, air pump, etc.
All the AC components.
Power steering pump. And bracket.
2ndary throttle plates.
Aux port sleeves and actuating rods.
And a bunch of other misc. parts from the engine bay. Like sub-zero start tank, washer fluid tank, etc, etc.
Old 03-21-2011, 05:09 PM   #48
N.RotaryTech
Home-brew Rotary
So the 7 has been down for upgrades since 10 days ago, I'm not going to post about it yet as not to jinx it.
But I will show a little something on the side from the main project.
This:
I decided to try out Fiberglass work for the first time, and repair an old under-tray.
The works a little messy, but I can handle it.
And I know it looks like crap.
I followed the directions from the can, and used about 4 squares of fiberglass.
That's it for now.
'87 RX7 GXL, Rest In Pieces.
'94 Ford Ranger, daily.
Old 03-22-2011, 09:06 AM   #49
ChaserAero
www.aerokits.net
ChaserAero's Avatar
ChaserAero is on a distinguished road
If it works, it works.
Chaser Aerodynamics, LLC
Please visit our website!!
Use coupon code: JB1013 to save 10% on your web order!
(866) 360-KITS (5487) ext: 107
ChaserAero is offline   Reply With Quote
Old 03-22-2011, 10:40 AM   #50
Not like anyone sees it.
I say good job.
Old 04-14-2011, 12:33 PM   #51
N.RotaryTech
Home-brew Rotary
Well after a month of working on it, I got it started last night, and took it for a drive at noon today.
I still have a few bugs to work out, like an exhaust leak an such.
That's it for now.
Old 04-15-2011, 11:52 AM   #52
N.RotaryTech
Home-brew Rotary
Alrighty, I'm so excited about this.
Here's what I've done,
Last year sometime I acquired a Turbo setup for cheap. Turbo, manifold, downpipe, intercooler, and some elbows, included.
I finally got to doing the project a month ago.
Finished it a few days ago.
Pictures and details coming very soon.
I am taking it to DGRR and the Mitty.
I think from where I'm coming from, when I get back home, Ill have around 1000 extra miles on it.
This is going to be one heck of a break-in. lol.
Old 04-18-2011, 10:42 AM   #53
N.RotaryTech
Home-brew Rotary
My Turbo project!!!!
Ok, continuing what my previous post says about this turbo set up, let me get the pictures & details rolling.
Some picture sets might not be clear of the progression of things, I was more concentrating on building this project, but I think you'll get it.
First the turbo setup I acquired.
(Post downpipe modification.)
I started modifying the down pipe cause it was too long as to fit in between my RB silencer and the turbo.
As i took off the RB silencer the studs got fubared.
I ended up shortening the totally stripped stud, and cut away a thread or two of the other stud, cause the fastener I used was hanging up.
This is what it looks like now.
I took it to a local car repair service center to get it welded together.
Added the extra O2 sensor bung later.
Future plan for this downpipe is to sand it down and cover it with hi-temp paint.
Old 04-18-2011, 10:50 AM   #54
N.RotaryTech
Home-brew Rotary
Next, I fabricated the intercooler mounting.
I didn't even have to move the overflow tank or the horn. I did reroute the coolant tubing though.
I painted it black.
Old 04-18-2011, 11:02 AM   #55
N.RotaryTech
Home-brew Rotary
Changing the fittings on the turbo.
This is what i used for the oil feed line for the turbo. Parts from the plumbing section at Lowes. They are for Faucets.
Here I fabricated some heat shielding for the turbo.
Old 04-18-2011, 11:29 AM   #56
N.RotaryTech
Home-brew Rotary
Intercooler piping. I used exhaust tubing from o'reilly auto parts.
Painted.
I modified an intake pipe from a Subaru Impreza and used it for the intake pipe for the turbo. I cut a lot of things off of it to fit and used epoxy to fill the holes and seams.
I cut apart my old cone air filter to make a filter element for the MAF sensor. A normal size filter wouldn't fit in the engine bay.
I installed 750cc injectors in the secondary's and rewired the connectors from S5 to S4.
Parts, gaskets, etc.
Old 04-18-2011, 01:09 PM   #57
N.RotaryTech
Home-brew Rotary
Finished project.
Kind of tight on the passenger side of the engine bay, but this is how things look.
I drilled a hole next to the radiator. Blitz BOV I traded some parts for. Used some clear tubing I had around instead of normal vac tubing which I didn't have.
The sun was killing this shot, but shows the IC piping.
The Subaru Impreza intake pipe installed.
I used an S4 turbo MAF sensor, changed the connector wiring, and have a piece of filter clamped on.
View from above the turbo. One of the heat shields, Oil and coolant lines installed. Also one of my attempts to fix an exhaust leak. I still have a leak.
Oil feed line and source.
Oil return.
Oil temp source via T fitting.
Old 04-18-2011, 01:13 PM   #58
N.RotaryTech
Home-brew Rotary
And boost gauge, with a switch for the gauge light.
Old 04-18-2011, 01:53 PM   #59
N.RotaryTech
Home-brew Rotary
Now for the details.
The turbo is a Turbonetics T3/T4 series, I forgot the specs, I wrote them down someplace, have to find that.
It has an external wastegate that apparently came with a 10 pound spring in it.
720cc (not 750cc as I posted before) injectors in the secondarys, with 6 ohm resistors installed inline with the wiring to them, actually located next to the ECU under the carpet.
Stock Turbo AFM.
Stock TII intercooler.
Blitz BOV.
The engine is the same as I posted before. S4, 9.4 comp rotors, mild porting on the housings and end-plates.
And for the best part...
All this runs on the stock S5 NA ECU!
It will boost up to 10psi, but runs really lean up in that range.
Around 5psi AFR's are perfect though. 11's and 12's
Ive taken it for a drive / boosting just a handful of times.
But found out last night after a drive that my Nopi stage 2 carbon kevlar clutch filled the engine bay with burnt/slipped clutch smell.
So I might have to replace it after DGRR'11
I also found that the turbo's oil seals are bad, leaking through the exhaust and leaking externally.
So with all this, I'm expecting a possible clutch, turbo & engine rebuild after DGRR'11.
Old 04-18-2011, 02:24 PM   #60
My5ABaby
My5ABaby's Avatar
Any concern with those oil hoses not being made to withstand petroleum/heat?
Community Service Manual
RotorWiki
