Old 01-25-2011, 09:47 PM   #1
Fuel Sender Resistance
Hunting for fuel level gauge and need to know the ohm range and correlation to full and empty.
Old 01-25-2011, 11:20 PM   #2
NoDOHC
NoDOHC's Avatar
I should be home to test this for you on Thursday. I don't know off the top of my head.
If you don't get a reply by then, I will get you the info (should be in a sticky somewhere - sensor specs on a 2nd gen, 3rd gen, etc.
Old 01-25-2011, 11:46 PM   #3
I thought so too... I even tried checking out the www.rotorwiki.org, but it seems like it's offline!
Old 01-26-2011, 09:00 PM   #4
JerryLH3
JerryLH3's Avatar
JerryLH3 is on a distinguished road
For the stock fuel gauge?
The 1991 FSM lists 7 ohm when full, 32.5 ohm at half, and 95 ohm when full.
EDIT: The above values are what it lists for the gauge itself. For the in-tank fuel level sender it lists, 3 ohm, 33 ohm and 110 ohm for those same three values.
Jerry
1991 Mazda RX-7 Turbo - the current project/money pit
JerryLH3 is offline   Reply With Quote
Old 01-26-2011, 09:43 PM   #5
What page number did you find that information on? I checked the FSM for the S4 and didn't see it (I don't personally believe they would have altered the resistance between the two).
Old 01-26-2011, 11:20 PM   #6
JerryLH3
JerryLH3's Avatar
This is on page T-50 and T-51 of my 1991 FSM.
Jerry
Old 01-27-2011, 01:58 PM   #7
I can't find a similar numbering convention on the FSM for the S4. What section did you find it in? I've checked the fuel and emissions section and didn't see it. Nor did I see it in the engine electronics.
Old 01-27-2011, 02:45 PM   #8
My5ABaby
My5ABaby's Avatar
As I recall the S5 FSM is much better than the S4.
Community Service Manual
RotorWiki
Old 01-27-2011, 02:54 PM   #9
Pete_89T2
Pete_89T2's Avatar
FWIW, the '89 FSM lists the same info on pages T-39 - T-40, "Body Electrical System" chapter. BTW, there's a typo above - the 95 ohms for the gauge is when it's on empty.
Old 01-27-2011, 04:00 PM   #10
JerryLH3
JerryLH3's Avatar
Whoops. I did indeed mis-type that. The last value is empty.
Jerry
Old 01-27-2011, 08:54 PM   #11
Found it in the S4 FSM:
Body Electric: 15-30 15-31
Sender Resistance: 3ohm Full, 32.5ohm Half, 110ohm Empty
Gauge Resistance: 7ohm Full, 32.5ohm Half, 95ohm Empty
So now the question becomes can a 90/0 gauge work?
Old 01-28-2011, 06:40 AM   #12
Pete_89T2
Pete_89T2's Avatar
This should would work, if 90/0 corresponds to empty/full. Needle might be a little off the marks, but not likely enough to matter. Keep in mind the stock wiring will add a couple of ohms series resistance to the circuit, so you're pretty close to the stock figures.
Old 01-28-2011, 09:13 AM   #13
My5ABaby
My5ABaby's Avatar
You can always add a resistor into the wiring.
RotorWiki
Old 02-03-2011, 02:25 PM   #14
Sharingan 19
Sharingan 19 is on a distinguished road
Or just make a custom gauge cluster setup....
Honestly THIS is one of the main reasons I made my setup. I figure why go through all the hassle to still have a stock fuel tank and replace one of few stock parts that works w/o issue. Might as well have something that looks cool if you like wiring.
Sharingan 19 is offline   Reply With Quote
Old 02-03-2011, 02:39 PM   #15
lol, you mean something like:
