Old 01-12-2011, 05:47 AM   #16
Judge Ito
Porting Master
Judge Ito is on a distinguished road
on my own personal 13B I tried roller bearings on the front and rear stationary gears over 6 years ago. there is pros and cons..
Judge Ito is offline   Reply With Quote
Old 01-12-2011, 09:21 AM   #17
Still running? Die a painful catostraphic death? Pics? Care to share more of the first hand experience?
Old 01-12-2011, 11:29 AM   #18
FC Zach
FC Zach's Avatar
I'm curious as well.
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 01-12-2011, 11:37 AM   #19
Judge Ito is such a tease . Count me in on wanting to see the aftermath of the roller bearings/engine.
Old 01-12-2011, 04:08 PM   #20
2gslse
Pics or it didn't happen!!!
2006 VW TDI commuter
Old 01-12-2011, 10:11 PM   #21
sickofpistons
sickofpistons's Avatar
sickofpistons is an unknown quantity at this point
I found this information if any dedicated rotary fan is interested.....check it out!
http://www.precisionenginetech.com/t...edle-bearings/
http://www.southshorebearing.com/bearings.htm
http://www.daltonbearing.com/iko/iko...-bearings.aspx
http://www.directindustry.com/indust...ing-60788.html
Has anyone ever had a radial trust bearing fail in your engine? There are to many bearing designs, so there has to be a better alternative that will reduce friction and increase HP! Im only tryin to contribute to the forums knowledge and FLOW of IDEAS.
sickofpistons is offline   Reply With Quote
Old 01-12-2011, 10:37 PM   #22
My5ABaby
My5ABaby's Avatar
If they're better, why wouldn't Mazda use them?
Community Service Manual
RotorWiki
Old 01-12-2011, 10:40 PM   #23
Price.
Old 01-12-2011, 10:47 PM   #24
sickofpistons
Faster production....? Lower costs, and more money in there pockets... i geuss. Lol wouldnt you think so?
Old 01-12-2011, 10:49 PM   #25
Longer service life and quieter too
Old 01-14-2011, 09:58 PM   #26
sickofpistons
Well i found a donor car NA 88 I think it has a blown coolant seal. But anyway im going to try and cheap bastard rebuild, lmao with different bearings and see what happens. Im fasinated with rotaries and would love to contribute to any design or improvement. If anyone needs any designs of parts im proficient with AUTOCADD, so hit me up!
\,,/_ _\,,/ GIGADY
Old 01-14-2011, 10:46 PM   #27
NoDOHC
NoDOHC's Avatar
Hey, you can't argue with that - does the ideation and the testing.
Good luck with the build!
(Ideally you could dyno it with journal bearings and roller bearings).
Old 01-14-2011, 10:49 PM   #28
sickofpistons
Thanks for that, what would a 13b na basic bone-stock have with HP just to compare after this Ideation and testing?
Old 01-25-2011, 11:57 AM   #29
Depends on a lot of factors. Port size, geometry, compression, measuring location, flywheel weights, etc, etc, etc.
Old 01-25-2011, 11:01 PM   #30
NoDOHC
NoDOHC's Avatar
My S4 NA stock ECU with 7 degree advanced timing and 4 clicks lean on the AFM made 138 WHp per my G-Tech (which I have found to be pretty accurate).
I think (although I didn't copy the run to excel - so it's just from memory) that the S4 NA with a manual transmission did about 118 WHp with stock timing and stock AFR.
My S5 Automatic with stock timing and stock AFR (can't adjust S5) runs 102 WHp per the G-Tech. Made 120 WHp with 7 degree advanced timing.
