Old 10-15-2010, 10:46 PM   #1
1Revvin7
Turblown Engineering
1Revvin7 is on a distinguished road
496rwhp FC3S
Large Port 2nd gen
TD61( 1.15 P trim GT35R BB)
400cc 50/50 water alcohol with 91 pump
3" exhaust, open waste gate
HKS DLI, Greddy 10s
20psi
Ran out of fuel at 5200~ish rpms as you can see the torque curve drops off. Peak torque was 467. Pump is a rewired single walbro. Going to be adding a 2nd possibly, or lowering the boost pressure. Didn't really think this thing would make this much power. Probably following up with a completed dyno etc..
Turbo http://www.turblown.net/store/index.php?productID=10
Rx-7 Turbo Kits, Engine Building, and Parts
www.turblown.net
1Revvin7 is offline   Reply With Quote
Old 10-16-2010, 12:35 AM   #2
soldave
soldave's Avatar
soldave is on a distinguished road
What is the full spec on that car? Nice figures though
Big in Japan: soldave.ismysite.co.uk
soldave is offline   Reply With Quote
Old 10-18-2010, 05:55 PM   #3
1Revvin7
Its a gutted road race car, with cage and full fluids weighs 2600lbs on our scales. Usual stuff, Ksport coilovers, Bomex bodykit, 4" cold air intake, 4 core FMIC, 550/1680cc injectors, Haltech e6k, etc...
Not sure what else you want to know for specs?
We are plumbing dual walbros and doing some bushings right now..
Going back to the dyno next week...
www.turblown.net
Old 10-21-2010, 09:46 PM   #4
NoDOHC
NoDOHC's Avatar
Congrats on the numbers!
Could you post ignition timing and AFR?
Maybe you could log injector energizing time so that we can add it to our BSFC spreadsheet. Or maybe determine fuel rate more accurately using a scale.
Old 10-30-2010, 12:30 AM   #5
1Revvin7
Ignition timing is around 8 degrees on the top end at full boost. That should give you an idea of the timing map...
23psi and a little leaner...
http://www.youtube.com/watch?v=1IGz6E1GBNI
Old 11-10-2010, 09:06 PM   #6
NoDOHC
NoDOHC's Avatar
Could you post AFR during that pull?
Old 11-11-2010, 12:15 AM   #7
1Revvin7
10.7 AFR past 20psi
