Old 08-25-2010, 10:10 AM   #16
GeneralPatton
GeneralPatton is on a distinguished road
Default
Emissions test huh?
Why dont you stop farting while you are in the car.
GeneralPatton is offline   Reply With Quote
Old 08-25-2010, 10:13 AM   #17
Boosted FC
Rotary & Boost Addict
Boosted FC's Avatar
Boosted FC is on a distinguished road
Default
Why hasn't this guy been banned yet? Phil, Kevin?
'05 Copper 6s, '87 TII RX7...248whp & 224wtq @ 12lbs
Boosted FC is offline   Reply With Quote
Old 08-25-2010, 07:42 PM   #18
RotorDad
Big Ugly
RotorDad's Avatar
Default
Ignore the assbag, these fools like the attention!
Boosted Big Body On 335's
PS3 ID: Rotordad
Old 08-26-2010, 09:35 AM   #19
GeneralPatton
Default
Haha. Shel should already know that
Old 08-26-2010, 11:00 AM   #20
Boosted FC
Boosted FC's Avatar
Default
lol, unfortunately I do
Old 09-08-2010, 05:48 PM   #21
tweiss3
Mazda Lover
tweiss3's Avatar
Default
Ok, got it on the road just fine. Ran a full tank and a half of fresh fuel. Tried to e-check it today (emissions in ohio) and I failed:
As you can see, Im fine on CO and NO, but my hydrocarbons are only slightly over. Anyone have any idea on what to do to it to make it pass. Fresh fuel, new remanned air pump, new plugs, new wires (ngk only) and it is getting about 140 miles to half a tank. Its NA and the only thing i didn't replace was the air filter. What do you guys think?
Old 09-08-2010, 10:19 PM   #22
NoDOHC
NoDOHC's Avatar
Default
Unfortunately, this looks like your catalytic converter is weak or you are misfiring at idle.
Do you have the entire emission run printout so that we can see if it cleans up after going closed loop?
You are very close, I have seen people get a pass after a fail like that just from taking the car around the block and getting it good and warm.
You can try the 2-3 gallons of e85, it helped mine years ago.
Be careful about too much E85 (don't ask, sore subject).
Hydrocarbons are the rotary nemesis when it comes to emission testing.
Old 09-09-2010, 05:08 AM   #23
tweiss3
Mazda Lover
tweiss3's Avatar
Default
Unfortunately that is the only print out i get. If the catalytic converters are not up to par since they are the origionals, would this magnaflow direct fit work? here It eliminates the precat and add it to the main cat. Summit has it for 200, or i got a quote for 300 to get it installed at this shop. That 300 would put me in the category that if i didn't pass i could get exempt. My issue is I shopped around and nobody has the OEM at all.
Old 09-09-2010, 05:08 AM   #24
tweiss3
Mazda Lover
tweiss3's Avatar
Default
Also, there is no E85 around here that I know, would adding something like "heat" to this next tank work?
Old 09-09-2010, 02:39 PM   #25
tweiss3
Mazda Lover
tweiss3's Avatar
Default
well, running out of time, i wen ahead and ordered the 2 to 1 cat direct fit. 220 with tax, which will either pass me, or get me a hell of a lot closer to the waiver.
Old 09-09-2010, 07:32 PM   #26
NoDOHC
NoDOHC's Avatar
Default
Yeah, the 'heat' is methanol which is very similar to the ethanol in e85.
Either way it is oxygenated fuel.
The new cat will likely fix your problem, but the rotary EGT will melt it into a glob of metal in about 2,000 miles if it is tuned correctly. You might want to find a way to put the stock ones back on after the test.
Old 09-09-2010, 08:38 PM   #27
tweiss3
Mazda Lover
tweiss3's Avatar
Default
I plan on removing the cat itself and inserting a resonated test pipe. Fresh hardware and such so that going back to emissions mode is easy.
Old 09-09-2010, 10:44 PM   #28
NoDOHC
NoDOHC's Avatar
Default
That works too (although I wasn't going to be the one to suggest it).
I had cats on my car until I found that they melted down almost immediately if I left them on, then I just put them on to pass emissions.
They did away with emissions here, so it isn't an issue any more.
Old 09-10-2010, 05:17 AM   #29
tweiss3
Mazda Lover
tweiss3's Avatar
Default
Well, i have to pass now, then in january cause of some dumb loophole shit they have in the regulations. Im not about to drop that kind of money on cats twice
Old 09-10-2010, 10:22 PM   #30
NoDOHC
NoDOHC's Avatar
Default
If you leave the stock ECU in and don't change the fueling, your cats will probably be ok until January. My issue was that I was running 16:1 AFR while cruising.
I could meet emissions with my standalone, but I couldn't afford the 10 mpg penalty that I would take to do so.
Ad Management by RedTyger
