Old 06-30-2010, 02:20 AM   #316
project86
Can't.Make.Up.My.Mind.
project86's Avatar
Originally Posted by Max777 View Post
Sure! To fix the problem you speak of, it will require the use of what's called a "BIG FUCKING HAMMER", yes?
haha ok then sounds good. thats what ill do. i guess if i screw up the flywheel it really doesnt matter cause i dont need it anyway. ill give it a shot. i even put a puller on it and she still wouldnt budge.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 06-30-2010, 06:15 AM   #317
No. Soft Face hammer and hit the flywheel @ 12, then 6,9,3,12,6,9,3,12,6,9,3 and keep giving it solid hits until it pops off. Make sure the flywheel nut is still on though otherwise you may hop away missing a toe or two.
Old 06-30-2010, 11:32 AM   #318
project86
project86's Avatar
i tried that for a long time yesterday and im not getting anything. im kinda wondering if i should have left the front cover on? the only movement im getting out of it is just the eshaft moving back and forth with it.
'90 GTUs
'10 Toyota Prius
Old 06-30-2010, 06:30 PM   #319
I've never had an issue getting it off with a dead-blow hammer. Meaning a rubber mallet. Try a brass hammer, or a heavy ballpien against a piece of AL against the flywheel. Keep hitting..... pretty hard too.
Is this a one piece flywheel or an aftermkt flywheel with the auto counterweight?
Old 06-30-2010, 07:23 PM   #320
project86
project86's Avatar
I beat it hard today.......and i finally got it off. got the whole engine apart too. to my suprise everything in there looks pretty good. ill post some pics of it later but i think what ill do is get everything cleaned up and buy a seal kit for it and porting templates and put it all back together and throw a carb on it.
'90 GTUs
'10 Toyota Prius
Old 06-30-2010, 07:32 PM   #321
What about the other pj?
Old 07-01-2010, 12:47 AM   #322
project86
project86's Avatar
you mean for my car or the body work pj im doing now? im still planning on the awesome thing for my car. i just wanna try my hand at rebuilding this engine just for shits and giggles. id like to find an rx2 or 3 to put it in and race it till it blows.
'90 GTUs
'10 Toyota Prius
Old 07-01-2010, 03:54 AM   #323
haukbeeb
haukbeeb is on a distinguished road
Other project is somewhat in limbo. Waiting on a compressor to run the gun and DA.
Oh wait.....are you talking about my project or project86's?
haukbeeb is offline   Reply With Quote
Old 07-01-2010, 05:51 AM   #324
kyles other engine pj.
Take it from someone who's DA'ed cars with an air DA...... spend the money and get an electric DA. Your compressor will thank you
Old 07-01-2010, 11:12 AM   #325
project86
project86's Avatar
hahaah Brian you do know i have been putting an air DA to cars for 2 years now right? I have a really nice Snap On DA and the compressor im buying will be plenty for it to work
But i just had a thought last night that i was chattin with haukbeeb about. My dad actually made me think about it.... im gonna rebuild my old engine and put it back in my car with a carb until its time for the super sweet other engine just so i can enjoy my car a little.
Im gonna buy some porting templates from pineappleracing.com and then i may buy a few porting tools from racing beat (unless someone can lend me some. I got the rotors cleaned up quite a bit yesterday and if all goes well im gonna have the irons hot tanked.
Then ill order a gasket and o ring kit from mazdatrix. i dont think it should cost me too much to do this and it will keep me happy till its time for the BIG project.
'90 GTUs
'10 Toyota Prius
Old 07-01-2010, 07:53 PM   #326
Hey man, I gotta 60 gal Cambel Hausfeld 13.5 hp air comp and after DA'ing for a while, it gets warm. Just a suggestion, though I bet the Snap-on DA you've got uses alot less CFM than the one I have.
Gotcha, makes sense. I've got too many cars and not enough time to enjoy any of them. Today was the perfect example. I had today off, as well as tomorrow and the weekend. I went in early this morning, got there @ 8 to do a bunch of side job/captaining stuff............. I just got home.... 13 hours later. Now I'll be busting ass all night
swapping a front knuckle - powdercoating it first
building a heat shield for the fuel cell
installing an amp
swapping rear ends
and washing, compounding, glazing and waxing the car. If I get on the rd by dawn I'll be happy. Otherwise, no dyno tomorrow......... again
Old 07-01-2010, 09:57 PM   #327
project86
project86's Avatar
Well thanks for the heads up on the DA thing. I just got my compressor today. Its only a 33 gallon but i wont be using the DA for extended periods of time back to back.
I hope i can get this engine back together with everything i need without having to spend toooo much money. i mean im not a cheap ass but things i need now that i can think of right off the bat:
Rad
Efan
Oil cooler
FPR
Carb and upper mani for it
All exhaust components
Distributor
Porting Templates/Tools
Gasket and oring kit
'90 GTUs
'10 Toyota Prius
Old 07-02-2010, 10:00 AM   #328
chibikougan
chibikougan's Avatar
I still have my S5 stock Radiator I think. If so its yours. Also you can have the Holley pressure reg from the FB. I am not sure on the oil cooler though I will look.
Old 07-02-2010, 12:36 PM   #329
NoDOHC
NoDOHC's Avatar
Are you going NA or turbo (I am guessing NA with a carb setup)?
If so, I would not buy a template, or 'tools', just get a few carbide burrs from Summit or JEGs and clean the factory ports up a little, the Pineapple Racing templates are really too big for NA. I have an engine that was proted with them and they delay the intake closing WAY too much to make any NA torque below 8,000 RPM. This is a setback because you will need a pretty special intake manifold and really good runner flow to get air to the engine at that speed.
Seriously, just clean the stock port up a little and work with that. Your WHp, torque and drivability will thank you.
Pineapple racing templates are good for turbo applications as they lower the dynamic compression ratio, allowing you to run more boost.
Don't forget that the intake runners make as much difference in power and volumetric efficiency as the ports, the only difference being that properly sized runners don't kill your low end torque (although they hurt it a little) or your idle quality.
Old 07-02-2010, 10:15 PM   #330
project86
project86's Avatar
Yes NA. I just wanted to play around with my old engine so im not really too concerned with it right now. Its more of an experimental thing for me. I do appreciate the heads up though
I just wanna screw around until its time for the real project to begin and i thought that would be a good way to do it.
Also judging by some reading ive been doing i should ditch the 3pc apex seals for 2pc... but i dunno if i wanna spend another 300 or more for new apex seals when this is really just for shits and giggles. My seals look fine. I do need new eyelets for the corner seals though. and new corner seal springs.
'90 GTUs
'10 Toyota Prius
