Old 06-19-2010, 02:17 PM   #31
Bigshanks2002
Bigshanks2002 is on a distinguished road
my 91 JDM S5 is doing the same thing. it seems as though the secondary injectors might not be kicking on. The main realy switches power to the 2 primary and the two secondary injectors individually. You need to start the car and pick up the idle to about 3000rpms and listen with a stethoscope (or a long screw driver to your ear) to see if the secondary injectors are ticking.
Bigshanks2002 is offline   Reply With Quote
Old 06-19-2010, 03:22 PM   #32
Uh...no.
Old 06-22-2010, 09:55 AM   #33
LunchboxCritter
Simply Rotarded
LunchboxCritter's Avatar
LunchboxCritter is on a distinguished road
That's not it, I figured out that I had the neutral switch wired up wrong. That was causing my problems.
I am now wondering if my chipped ecu wasn't in "limp" mode because of wiring mistake. If so, why would the N370 not have entered "limp" mode as well?
I'm considering throwing the n374(chipped) back in there and see what it will do now that the neutral switch is wired right.
LunchboxCritter
- 91 NA to J-Spec TII
- 88 FC Vert
- 04 Rx8
Disclaimer: I am not a mechanic, and I did not sleep at a Holiday Inn.
DO NOT TRY THIS AT HOME!!!
LunchboxCritter is offline   Reply With Quote
