Old 05-27-2010, 01:22 PM   #31
vel525
vel525 is on a distinguished road
Well, I'm in the process of swapping in a LS3/T56. I'll post some pics when it's done.
A-Spec 500R. 350rwhp@12psi.
GTC front, Feed sides, Re-Amemiya street diffusor, Pettit Racing GT flares, 99 CF Wing, CCW SP20 (18x10 and 18x11.5), Stoptech BBK, 99 spec rear brakes, Tein Flex coilovers, HID lights, etc.
vel525 is offline   Reply With Quote
Old 06-02-2010, 03:20 PM   #32
FC3S Murray
frustrated!
FC3S Murray's Avatar
I am joining the club. I am going LS1 but am shooting for 400 rwhp.
Same pig, new soul
Old 06-02-2010, 08:50 PM   #33
^ hmmmm, so basically one too many?
Old 06-05-2010, 10:41 PM   #34
FC3S Murray
frustrated!
Like a damn torn in my side
Same pig, new soul
Old 06-06-2010, 09:55 AM   #35
project86
Can't.Make.Up.My.Mind.
project86's Avatar
you two are like a married couple..........
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 06-17-2010, 11:05 PM   #36
Lol... 400whp v8
Old 06-27-2010, 04:44 PM   #37
acuracy00
acuracy00 is on a distinguished road
LS2 FD here from Wisconsin
acuracy00 is offline   Reply With Quote
Old 08-01-2010, 07:29 PM   #38
rotaryride
rotaryride is on a distinguished road
In my opinion what makes a real rx7 unique is the rotary. That's why I love RX7's just because of the rotary.
rotaryride is offline   Reply With Quote
Old 08-01-2010, 11:41 PM   #39
josh18_2k
cool story bro
Old 08-30-2010, 02:02 PM   #40
rx7man1993
rx7man1993 is on a distinguished road
I am in the process of converting to the dark side as the rotary community likes to say, but as I read a few post up, the fix or repair (costly repair) daily thing has come to an end.
I have a 93 BASE model I am putting a LS1 from a Firebird with a T56 tranny. Here is what I am doing to her!!!
Block Stock 2000 LS1
Crank Stock 2000 LS1 (Stock Stroke)
Rods Stock 2000 LS1
Pistons Stock 2000 LS1
Compression 10.2:1
Cylinder Heads CNC-Ported 5.3L Truck (Total Engine Airflow)
Cam COMP XR265HR
Lift .522/.529
Duration 212 In., 218 Ex.
Intake Manifold FAST LSX
Throttle Body FAST
Injectors 36 lb.
Management System FAST
Should get me into the 500hp range and 475torque. I am redoing all the wiring and doing a wire tuck so you will so no wires except those for the engine wiring. I am also going to put dynomat throughout the cabin. I am putting true duel exhaust with magnaflow mufflers. I am not sure which subframe system I am going to use as I have a few more parts to sell. I do have an engine though already. I already have a massive about of aftermarket parts that are on the car. Tein coilovers/susp upgrades, dual pumps in the tank, aftermarket gauges, sloted rotors etc....
I have been throught 2 rebuilds and I am just fed up with the hassel and headache over the beloved rotary. I never intended to going with the LS1 but things have changed.
rx7man1993 is offline   Reply With Quote
Old 08-31-2010, 03:58 PM   #41
FC3S Murray
frustrated!
Block Stock 1998 LS1
Crank Stock 1998 LS1 (Stock Stroke)
Rods Stock 1998 LS1
Pistons Stock 1998 LS1
Compression 10.2:1
Cam COMP XR265HR
Lift .522/.529
Throttle Body FAST
Injectors 36 lb.
Cool. You going to at LEAST upgrade the rod bolts since your engine year is the weaker series?
Same pig, new soul
Old 09-01-2010, 06:31 AM   #42
rx7man1993
I will be upgrading any issues that may become a problem. I am going to eventually twin turbo the engine also. I want to get into the 800hp range.
