Old 05-01-2010, 02:10 AM   #1
85'12a-Blake
1stGen 4 a 1st Rx
85'12a-Blake is on a distinguished road
dead FB; engine won't spin
well just any other night after work waitin for the manager 2 come out and while i was waitin. something poped in my car and it locked down. i figured out it wasnt the starter. IT mite be a possibilty of the throw out bearing since it was going bad but it still rolls and takes gear. if thats not it then its gotta be internal. Any ideas, its a 12a with 146k on it stock. any suggestions as 2 the problem would be great but will be starting the tear down soon once i get it home. just 2 say ahead of time this is my first rotary so its ok 2 talk 2 me like an idiot b/c i probly wont understand all of the technical lingo
Last edited by Phoenix7; 05-28-2010 at 02:44 PM. Reason: edited title to reflect content
85'12a-Blake is offline   Reply With Quote
Old 05-01-2010, 11:09 AM   #2
Kentetsu
Kentetsu's Avatar
Ouch! With the tranny out of gear, can you rotate the motor by hand?
Old 05-01-2010, 11:32 AM   #3
85'12a-Blake
1stGen 4 a 1st Rx
nope motor still dont move....its locked down good....i havent taken a breaker bar 2 try it since it isnt home yet....but it wouldn't move with the starter.....
Old 05-01-2010, 12:36 PM   #4
IH8DSM
IH8DSM's Avatar
Did you check the oil? Could of ran low on oil and seized or bearings toast
Old 05-01-2010, 12:56 PM   #5
85'12a-Blake
1stGen 4 a 1st Rx
oil level and coolant both are good. but dad said the oil smelt burnt.....idk but he's been building cars for over 30 yrs but not rotarys but still i had the oil changed 1200 miles ago.
Old 05-01-2010, 02:04 PM   #6
IH8DSM
IH8DSM's Avatar
what kind of oil do you run, did you see in copper in the oil?
Old 05-01-2010, 03:04 PM   #7
85'12a-Blake
1stGen 4 a 1st Rx
idk about the copper in the pan but there wasnt any in the oil on the dipstick. it was Penzoil conventional 10w-40. IT's still sittin @ work not home
Old 05-01-2010, 04:41 PM   #8
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
time for a new engine, unless your throw out bearing wore down and broke some teeth out of your pressure plate that wedged themselves into the flywheel. its happened to me
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 05-01-2010, 06:39 PM   #9
85'12a-Blake
1stGen 4 a 1st Rx
well thats kinda what my dad said b/c the throw out was gettin pretty loud but didnt have the cash for one and a clutch 2. but we will see soon i just hope if it is the motor that its not too destroyed inside
Old 05-01-2010, 10:11 PM   #10
12arotary
12arotary's Avatar
if the motor is locked up at least one rotor will be totally demolished 100% guaranteed.
a good way to figure out whether or not its the clutch- the motor will spin backwards so through a socket on the front and try
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 05-02-2010, 12:04 AM   #11
85'12a-Blake
1stGen 4 a 1st Rx
i'll try that 2moro if i got time but i'll be gettin it home monday so i'll just pull it then and find out but thanks appriciate the info
Old 05-04-2010, 07:17 AM   #12
85'12a-Blake
1stGen 4 a 1st Rx
well i took a breaker bar 2 it this morning and it broke free but i didnt try a compression stroke. So hopefully that means its the throw out bering and clutch and all that fun stuff.
Old 05-04-2010, 09:37 AM   #13
12arotary
12arotary's Avatar
you should have been able to tell where the noise came from and if it wasn't the engine it should fire right up
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 05-04-2010, 07:39 PM   #14
85'12a-Blake
1stGen 4 a 1st Rx
well rlly the only noise i heard when it broke free was me fallin on my A** and the wrench falling.....but it feels like it has compression....so you think its a good idea 2 try and start it b4 i tear it down and see?
Old 05-04-2010, 07:45 PM   #15
Kentetsu
Kentetsu's Avatar
Pull the trailing plugs one at a time, have somebody turn the motor over while you listen to the air puffs. Listen for an absence of puffs, or for a different rhythm between front/rear.
Good luck...
