Old 04-14-2010, 03:30 PM   #1
Rotarytech7
460Hp FullStreetport N/A
Rotarytech7's Avatar
Rotarytech7 is on a distinguished road
Arrow should I cut the springs???
Here's the deal...I plan on buying springs later on but right at this moment I can't afford them...I was thinking of cutting my FCs springs just for the time being...wat do u guys think? should I?, and if so how much of the spring should I take off? If not y shouldn't I?
[[Anti-Piston]] ;P
Rotarytech7 is offline   Reply With Quote
Old 04-14-2010, 03:46 PM   #2
My5ABaby
My5ABaby's Avatar
If you want a crappy setup... Not worth the time or effort. You can pick up springs for like 150 or cheaper. Spend the time at work that you would have spent on cutting them and buy decent springs.
Community Service Manual
RotorWiki
Old 04-14-2010, 03:58 PM   #3
rotaryguy481
rotaryguy481 is on a distinguished road
I would deff not do it at all did it on my first seven worst ride ever and handling sucked as well
rotaryguy481 is offline   Reply With Quote
Old 04-14-2010, 04:37 PM   #4
12arotary
tumor-syphilis-itis-osis
12arotary's Avatar
if you just want a low car take out the springs and weld it ridged
82 300d
82 Gsl
84 b2200 Diesel
88 gxl
Old 04-14-2010, 05:30 PM   #5
Rotarytech7
Well thank u guys for the suggestions...I think I won't cut them... :P
[[Anti-Piston]] ;P
Old 04-15-2010, 09:50 PM   #6
actually, on the FC, as long as you do it right, it's not THAT bad... however, to make the car low enough in the back, you need to cut them to the point that when the shock is all the way extended, the spring has about a 3~4 gap from the top of it to the upper shock mount... this CAN be a problem, and it sucks to have to "Realign" the springs when you need to quickly jack up and lower the car again.
Old 04-16-2010, 01:59 AM   #7
Glad you'r enot doing it, you'd end up with a nice looking car that rides like shit.
