Closed Thread
Old 03-28-2008, 05:45 AM   #1
Barry Bordes
Barry Bordes's Avatar
Zero Clearance Side Seals
I like to set up my side seals as tight a practical. There are different thoughts on this minimum spec.
I have seen recommendations from .002” -.004” for turbo applications.
On my last engine build-up I mistakenly switched two side seals causing a
.002” clearance. This resulted in scrapping the RE front plate because of a
.004” wear groove on it in the area of combustion (where heat/expansion is greatest).
I decided to try .000”! Found this in an early Mazda paper.
What do you think?
Barry
Barry Bordes is offline
Old 03-28-2008, 07:37 AM   #2
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
The problem I see is the chance for the side seal to get jammed and loose compression on one face.
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline
Old 03-28-2008, 09:23 AM   #3
cewrx7r1
The Judge
Mazda's race prep manual lists .0039" to .0059" for 13Bs. But this is from 1996.
I do not know if this has changed.
cewrx7r1 is offline
Old 03-28-2008, 10:19 AM   #4
tom93r1
tom93r1 is on a distinguished road
Thats kind of a cool idea
tom93r1 is offline
Old 03-28-2008, 11:29 AM   #5
Barry Bordes
Yes Chuck you are right, but the regular workshop manual states .002"-.0059" and Racing Beat recommends .0015”-.004”( this may be a NA spec).
I guess I should have said it runs gap-less. It still has clearance to expand into the added corner seal slot.
Barry
Old 03-28-2008, 12:59 PM   #6
Signal 2
Viable Fossil
Signal 2's Avatar
Just thinking out-loud here....and I'm in the middle of only my first rebuild so go easy....
What about potential carbon build-up in that corner seal slot. I see some clearance for length, but is there risk with loss of what little "side" clearance there is within that slot due to expansion and/or carbon? What would be the result of the side seal and corner seal being effectively fused together if that happened?
Jim
VR R1 FD
Signal 2 is offline
Old 03-28-2008, 02:55 PM   #7
Barry Bordes
My swag (scientific wild ass guess) would be that it wouldn't much more of a problem. I'll have to tell you in a couple of years.
Barry
Old 03-29-2008, 05:31 PM   #8
GoodfellaFD3S
GoodfellaFD3S is on a distinguished road
I'd have to go check the feeler gauges, but I'm pretty sure I clearance side seals at .0015 to .002. Nice and tight, and havent had a problem yet. Of course, we recommend a pretty long breakin period of 1500 miles before serious boosting.
GoodfellaFD3S is offline
Old 03-31-2008, 07:19 AM   #9
Barry Bordes
This is the way to get a precision cut.
Barry
Old 03-31-2008, 01:58 PM   #10
Pretty neat barry!
So, are you going to be ready for DGRR??
Herblenny is offline
Old 03-31-2008, 09:43 PM   #11
a7xh7
a7xh7 is on a distinguished road
seems cool..
"sevens_ix"
a7xh7 is offline
Old 03-31-2008, 11:43 PM   #12
cewrx7r1
The Judge
Those special coner seals should seal better, but where can you buy them?
If you had a good machine shop, maybe you could make them yourself.
The question is, where they not cost effective for Mazda, or only used in rcae engines?
cewrx7r1 is offline
Old 04-01-2008, 07:24 AM   #13
Barry Bordes
Yes Chuck, I am not sure why Mazda hasn't used them for production. Possibly the extra machining and fitting.
I also wonder if the reason could be that the normal blow-by of the side seals might help to float the rotor between the housings.
As for who makes them, I make them myself with a special diamond cutting tool. I can cut a set for you.
Barry
Old 04-02-2008, 07:08 AM   #14
Barry Bordes
Phil, thanks for installing the picture correctly for me. How do you do that?
Barry
And I am still building my engine but expect to be there. I may have to go with Jack.
Old 04-04-2008, 07:32 PM   #15
afgmoto1978
afgmoto1978's Avatar
Barry,
Neat idea, but what about Apex seal clearance, assuming you had more clearance at the apex seal (two faces) you would see unwanted binding at the side seal from the apex seal rotating at the point of peak combustion pressure. Only one way to find out, and that's to test it out.
If money was no object, zero clearance on everything after Nikasil coating, or something of similar low friction properties. Ceramic coating......
afgmoto1978 is offline
Closed Thread
