Old 03-23-2010, 10:13 PM   #31
FC Zach
FC Zach's Avatar
1993 Yamaha GTS1000
1992 Celica Turbo AllTrac
1987 RX7 Sport
1979 Yamaha G1, KM24 powered
1975 Dolmar KMS4
Old 03-23-2010, 10:28 PM   #32
I got rotary love on my rig
We find it interesting that alot of rotary guys drive 4.0L Perfect complement to a rotary. Clean, reliable, good gas mileage, park whereever you want for x-mas shopping ... TORQUE @ IDLE
Old 03-24-2010, 12:28 PM   #33
DRTHVDR
DRTHVDR is on a distinguished road
Originally Posted by RotaryResurrection View Post
Okay, with all of you XJ lovers here, someone find me a decent wiring diagram for a 93 4.0L. I've scoured the net for 2 days now, and save for autozone, I've yet to find jack shit. The forum mods seem to be afraid to post anything for fear of a lawsuit, and the few links I've found are dead. Even with the overwhelming jeep following on the net, I cannot find any bootleg FSM's online either. What gives?
We have one that suddenly developed electrical issues...something is backfeeding juice into the main ignition circuit, meaning that it's impossible to turn the engine off even with the key out. Even if you pull a fuse to kill the engine, some of the other accessories remain powered with the key off including interior lights, gauges, dash warning lights, etc. I can't trace the problem because I can't find a good enough wiring diagram...and the f*(&^%^g fuse box isn't even friggen LABELED.
I have your issue into a Jeep Guru. Hope he has an answer for ya.
DRTHVDR is offline   Reply With Quote
Old 03-24-2010, 01:44 PM   #34
Wish I could help Kevin, I have a '98 FSM which does no good for '93 model. I will say it sounds like the main ignition relay is doing some naughty things, internally shorted. Lemme see if I have the old Haynes manual for my old '88 kicking around somewhere. They should be similar, at least it could tell you which fuse is what. If memory serves though, the fuse/relay locations and functions are in the owners manual
Old 03-24-2010, 06:28 PM   #35
2gslse
I feel left out I have a dodge W/318 V-8
Old 03-25-2010, 07:40 AM   #36
DRTHVDR
You have a bad ground somewhere. "Do the dome lights stay on and the ignition circuit won't shut down? Does it ever shut down? I'd go to the dealership and photocopy the pages that show the ground locations. Then I'd go check each one.
The factory manual has a section with each ground desgnation (i.e. G206) and tells what components ground through that connection. Then another section will show you a pic of G206 to help you phisically look at that connection.
You don't need a better ride, your ride needs a better driver.
93 RX-7 R1 CYM: Swap in progress
Other: 00 Impreza RS (GC8) & Odyssey Touring (Mommy Missile)
Old 03-25-2010, 08:46 AM   #37
eppo37
Rotarded Jackass :)
eppo37's Avatar
eppo37 is on a distinguished road
Worst DGRR thread EVER!
"There's a fine line between not listening and not caring. I'd like to think I walk that line everyday." - Loenard L. Church
User [yoo-zer] noun -the word IT professionals use when they really mean idiot
Hacking is like sex. You get in, you get out, and you hope you didn't leave anything behind that can be traced back to you.
eppo37 is offline   Reply With Quote
Old 03-25-2010, 08:54 AM   #38
DRTHVDR
LMAO!
It's very intriguing how fast a thread or topic can change.
BACK ON TOPIC!
Let's limit XJ work to PM's.
Old 03-25-2010, 10:07 AM   #39
ZGN
Administrator
ZGN's Avatar
thats is the 1st motor I ever rebuilt!
Kevin
Old 03-25-2010, 01:26 PM   #40
I also thought it may be a stuck on relay, but since nothing is labeled and I have no diagrams, I dont know what is what. Guess it is time to start blindly pulling relays one by one and see what happens...but that is a hard way to troubleshoot.
It's a decent way to find the relay, but not so good for tracing all the wires back and forth to find the short if one exists. If a burning smell was present, likely something rubbed through and or melted.
I dont really see how a bad ground could cause circuits to function when they are not supposed to. If those items were on a common ground that was bad, then those circuits would not be able to carry power even when you wanted them to...no?
I don't either unless the relay was gnd triggered which is rare in american cars. Usually a bad gnd causes circuits to stop functioning, not keep functioning.
It could be as simple as the ign switch itself went bad, or one of the wires leading away from it went to shit. There's alot of movement around the colomn and the earlier ones are known for getting loose. As in the wheel moves up and down becuase the column nuts became loose. That could easily short something out.
us129 closed
