Old 02-27-2010, 07:22 PM   #1
Talking '79 SA Reliability Build.
'79 SA 149k with 45k rebuild.
Good
- Beautiful Silver paint with "custom" pinstripes (not a fan of the Rx-7 Stickers)
- Very decent if not awesome interior
- Rock solid idle when warm
Bad
- One rust bubble on rear fender
- Noisy rear end (probably wheel bearings)
- omp lines were connected wrong, but immediately remedied
- oil cooler bracket is broken and currently held up with string... yes.. string...
Overall it's a 30 year old car that is in relatively excellent shape. Planning on fixing the rear end, giving the suspension/steering a once over, and doing the maintenance on the engine replacing vacuum lines, oil, plugs, etc. I has Autolite plugs in it, and while normally I would say only use NGK... the things idles wonderfully and runs decent, so they can't be too bad.
Photos taken just seconds after getting home in poor light.
Old 02-27-2010, 07:36 PM   #2
Where the hell is my finders fee?
Old 02-27-2010, 07:42 PM   #3
i let your dog live while you had a baby... and i owe you a beer... its man law you know
Old 02-27-2010, 08:19 PM   #4
My5ABaby
My5ABaby's Avatar
Nice. I'm actually feeling the decal/accents. They match the car well given its age.
Community Service Manual
RotorWiki
Old 03-02-2010, 08:52 PM   #5
Couldn't wait. I made a Indyparts shift boot fit the SA trim with a 5spd Rx-8 knob. Now its time to replace that radio, equalizer, and get new shifter bushings when I can... I used a crappy camera but the idea is there.
Old 03-02-2010, 09:19 PM   #6
FC3S Murray
frustrated!
FC3S Murray's Avatar
old school.....SWEET! In great shape man!
Same pig, new soul
Old 03-03-2010, 07:37 AM   #7
i need me an SA
Old 03-06-2010, 02:39 AM   #8
Trout2
Trout2 is on a distinguished road
The decals were from the factory or a factory option. My dad bought a 79 SA in July 1979, it came to the dealer that way - someone ordered it and didn't want it after we waited a couple of months for silver or blue. When the car was repainted in the early 80's, another set of decals was purchased but thankfully not applied. Looked much better in yellow w/o brown strips.
Jack
Trout2 is offline   Reply With Quote
Old 03-07-2010, 07:21 PM   #9
Werd thats good to know. He must have either copied the original decals before repainting (or copied someone elses). Were the Rx-7 decals part of that option or did he just get fancy, because I'm about to take them off.
Old 03-15-2010, 08:47 PM   #10
Bought a spare panel and added a radio with a pocket from mazdatrix. See above pic that shows a old two post radio and weird equalizer... I think this will add a little more functionality...
Old 03-15-2010, 08:52 PM   #11
That stereo is full of win.
Where'd you get it?
Old 03-16-2010, 08:31 PM   #12
IH8DSM
IH8DSM's Avatar
pretty fancy there paul, now you need to bring me those wheels to mess with one day
Old 03-21-2010, 07:52 PM   #13
UPDATE!
This first pic shows the trimming of the dash to fit the radio. Only took about a half inch on each side but I had to cut through two nuts welded to the back of the panel. Lickily, the two bolts for the dash aren't necessary and the whole center console is still strong and doesn't move. I drilled a small hole and used two sheet metal screws to hold the HVAC controls in the correctly location. The punch holed metal strip serves as a springy support for the radio which otherwise would be completely held up by the plastic front panel. Wiring was a breeze due to having the wiring diagram from www.foxed.ca and it works perfectly. next step will be to add rear speakers
Old 04-11-2010, 06:52 PM   #14
UPDATE:
She passed emissions with 5ppm and it is now fully registered. The warm idle is now 900rpm with a simple throttle cable adjustment (from 1200). Finishing prep work for the Gap.
Work updated:
- New rear wheel bearings and wheel cylinders
- New shifter bushings
- New tranny and diff fluids
- Adjusted dashpot and throttle cable which was affecting idle
To be done:
- Tint
- Front brakes and wheel bearings
- All coolant hoses
- Passenger side headlight motor
Old 05-24-2010, 01:39 PM   #15
Full tank of gas, nobody in it. 2440lbs.
Deal's Gap '10
