Old 02-23-2010, 05:00 PM   #181
project86
Can't.Make.Up.My.Mind.
project86's Avatar
350whp and driveability, sounds like another RE candidate, lol...
Honestly though, 400whp is pushing it on a BNR turbo IMHO. Its not impossible, but not just a bolt on and go situation... look at what Brian had to push to get over 400whp with his (stock I think) twins and his motor is S W E E T.
I dont recall and am too lazy to go back earlier in the thread, but is the idea to use a stock harness/ecu with an RTEK? If it is, and that 400whp is truly your goal, you wont make it with that setup... 400whp on a streetport S5 will need standalone and most likely a bigger turbo (not sure how big BNR is going these days, but the 60-1 seems to be the norm).
As an example, one of the guys I used to hang out with and cruise with had an S5 streetported (fairly aggressive) running the BNR 60-1 and made 343whp at 12psi conservatively with an LT10 microtech tuned by Steve Kan. Most guys that run these setups fall in and around that area. 2gslse with his FD (REW block) using the RX6 turbo is making 360ish whp (MC - correct me on the boost setting, but I think it was 14) on a very mildly ported motor running a power FC.
All I'm getting at is REALLY plan out the power adders and supporting EMS when looking for that 400whp magic. 350-375 is doable with the 60-1, but the question is for how long? Both guys mentioned above have been reliably driving their cars for more than three years now... I just hate pushing parts to their limits, just something to consider....
ill honestly be happy with 350. i dont need 400 but i was just using the 350-400 as an estimate. BNR rates their stage 4 build for 400 at like 15psi i do believe the last time i checked. and as far as ecu goes i plan to run the haltech e8. i knew those goals were not feasible with a piggy back. im going with the stage 3 turbo from bnr but i am open to other turbo options i just dont want so big that i cant enjoy the boost if that makes any sense.
'90 GTUs
'06 Toyota Highlander Hybrid
'10 Toyota Prius
Old 02-23-2010, 05:13 PM   #182
project86
project86's Avatar
As for the porting, I would shy away from an agressive streetport, if you want to keep the driveability manners, I would only give the intake ports a little tickle and not change the timing very much at all, in fact, I wouldn't change the opening at all. I WOULD port the exhaust, however I wouldn't change the closing. Basically, I wouldn't change the factories overlap at all.
I would look at other turbo's too, GT35R of course comes to mind with some of the TO4's etc etc, and anything over 350 I think the stock mani is really choking the engine and the turbo. I have the data to support that on the factory twins and I suspect it to be similar on the S4/5 mani's as well.
Here's what I would do, I would do it in stages. You obviously need an engine, turbo, intercooler, ecu.
If you have an ECU and a harness, than I would run the girl pretty much bone stock until you have the coin/time to upgrade things. With an Rtek, I wouldn't go farther than upping the exhaust, and intercooler, and I would certaily spend some time on the dyno pulling some timing out and getting the L's dialed in. I wouldn't do anything farther than a BNR on an Rtek and I would figure out a way to log EMAP too. I would do this to make sure that you're not pushing the turbo too hard, or choking the engine.
Next step is prep for more ponies. This would include fuel, ignition, intercooler and ECU. Keep in mind at this point you're still running a pretty stock ECU but you'll be able to get the most out of the setup. For an ECU, MoTeC all the way, take a look at the M2R as you can get into one of those for slightly more than a haltech/microtech, but of course I would rec one of the M"hundred" series becuase of the software, it's just incredible.
So now you've got a cherry engine, all the supporting mods in place, it's time for the ponies - tubular mani and a real turbo.
It may take you a year or two to get there, but you'll do it safer, and you'll have a more reliable setup at the end of the day, as opposed to a setup that is constantly pushed to it's very limits
Originally Posted by FC3S Murray View Post
I am speaking here HONESTLY......after having dealt with as much BS as I have the last three years in regards to chasing the "400" goal I cant help but admit that I sometimes I just wish I would have stayed at my last 300HP motor. That son-of-a-bitch was reliable(besides my Oil Pressure issue) and I beat on it all the time. True it wasn't the fastest BUT the amount of work I have invested and MULTIPLE hic-ups/ unexpected parts that have come up just to get my motor where it is today............at times doesn't seem worth it.
Granted I don't know what this current motor is gonna put down NOR how long it is going to last (hense why I am spending soooo much time researching conservative IGN L set-ups, fuel mapping and multiple failsafes both mechanical and electrical) AT least I can say I know if this motor fails it will be my hand since I know every part inside and out. Perfect example of this is look at my last motor AND Matt's current motor situation....it blows but goes to show if you get it built, get it done by a true credible company that stands by their word
Kyle what I recommend is you think long and hard about what you want. Research, research, RESEARCH multiple set-ups and keep in mind reliability rarely comes with ultra high performance.
You are a smart guy so what you decide will most likely be legit. My second child is due AUG 8th SOOO if you want to build or have the means to do it, give me a call.
BTW..if you do go stand alone, do what Brian says. I would have gone MoTec if I would have seen what it is capable of after seeing Brian's software. That shit is as good as the Pratt and Whitney Turbine Engine test cell managment system we use up on the hill.
Brian i like youre idea of doing it in stages. ive been thinking about that and going from 150-60is hp na to 350+ turbo engine is gonna be WAAAAYYY diff. and i know i said this already in my last post but just so there is no more confusion I AM GOING STANDALONE so with the suggestion of working my way up i think thats what im gonna do. that will be easeir to afford and i can upgrade when i have the funds. that way i can get used to the power diff as well. so im gonna make a list of parts regarding the turbo aspect of the build and engine tonight and ill post it. hopefully it will cut down on the confusion lol. i dont want any of you to think im REtard. thanks for all the support guys. Sean i will def let you know what i wanna do. i do have some thinking to do....... ill update again after i get off work tonght
'90 GTUs
'10 Toyota Prius
Old 02-26-2010, 02:46 AM   #183
project86
project86's Avatar
ok so i got my fenders and doors put back on today and started sanding them. i do have a couple spots that i have to spot prime but other then that the car will be ready for paint tomorrow... as for when ill actually get it in the booth .. .welll thats a whole nother ball game.
as for engine. i wanna go ahead and build for the power i want to make in the future but im gonna use alot of stock components to start with. such as stock top mount and turbo, injectors and so on. except for the computer. im gonna get the haltech and just run the pre set fuel map they have for s5. i figure by doing this i can get used to seeing how the fuel maps and numbers relate and so on. i feel like im repeating myself but i feel like actually typing all this out gives me peace of mind to know exactly where im going with this. forgive me for beating a dead horse......
'90 GTUs
'10 Toyota Prius
Old 03-01-2010, 08:58 PM   #184
project86
project86's Avatar
quick update on body. i masked a couple places for spot priming. hopefully i can get that done this week. there is sooooo much other shit in the shop now and the 2 cars that just got painted keep going back into the booth cause they keep fukin shits up. like buffing through clear coat bla bla bla. so hopefully paint next week. keep your finger crossed.
as for engine im lookin at some software now and im gettin a pair of fd rotors from a friend and gettin an eshaft from an 8 and 2 stat gears as well.
'90 GTUs
'10 Toyota Prius
Old 03-03-2010, 09:20 PM   #185
project86
project86's Avatar
ready for paint!!!!!!!!!!!!!!!!!!
'90 GTUs
'10 Toyota Prius
Old 03-04-2010, 11:38 AM   #186
FC3S Murray
frustrated!
FC3S Murray's Avatar
Originally Posted by Manchu View Post
hai guys
iam Manchu actually i don't understand complete what you say so plz i have request to you in real whats a matter
Same pig, new soul
Old 03-04-2010, 05:16 PM   #187
project86
project86's Avatar
im confused tooo?
'90 GTUs
'10 Toyota Prius
Old 03-04-2010, 08:11 PM   #188
sooooo, about that paint.....
Old 03-05-2010, 01:08 AM   #189
project86
project86's Avatar
lol.. well. im masked today. ill finish up tomorrow and paint next week. can i get a hoorah?! haha
'90 GTUs
'10 Toyota Prius
Old 03-05-2010, 09:51 AM   #190
chibikougan
chibikougan's Avatar
No but you can have a Hoooray silly.
Old 03-07-2010, 05:15 PM   #191
project86
project86's Avatar
so here is what i have been workin on during my down time from body work.............................................. ................................ black is before white is after enjoy
'90 GTUs
'10 Toyota Prius
Old 03-08-2010, 09:05 PM   #192
project86
project86's Avatar
I am painting friday!!!!!!!!!!!!!!!
'90 GTUs
'10 Toyota Prius
Old 03-08-2010, 09:36 PM   #193
FC3S Murray
frustrated!
Bad ass man!! I like!
Same pig, new soul
Old 03-10-2010, 04:40 PM   #194
Uhg... friday, i say tomorrow.....
want to come paint my car next, lol...
Old 03-10-2010, 05:54 PM   #195
project86
project86's Avatar
haha i say tomorrow too.. but unfortunately im waitin on some tards to redo stuff.. and id love to paint yours!!!
'90 GTUs
'10 Toyota Prius
