| Old School Rotary (Pre-1979) Pre-1979 Discussion including performance modifications and technical support sections |
Rep Power: 17 ![]() |
Stredrotor's RX4 Coupe * Project 20B *
Thought I'd start a thread on my 1974 RX4 hardtop.
I bought around 2 years ago after previously having a 13b turbo 1973 RX4 hardtop and an '86 Series 4 RX7 turbo over the last 15 years. The car had a carby 13b and first gen RX7 5 speed, it ran well but I needed more power. I think of the RX4 as mazdas "muscle car" so it needed a engine with the muscle, hence a 20b ![]() The RX4 as I bought it.... ![]() ![]() ![]() Striped and painted the crossmember and replaced tie rods, sway bar and bushes. ![]() All installed!
The next acquisition for the 20b project, a series 5 gearbox
. ![]() I got a awesome bargain the other day, a bloke at work tipped me off to some 16 inch F90 Simmons at a second hand shop. A bit of bargaining and these were mine for $140. ![]() All 8 inches wide. Picked up a Microtech LTX12, coils, loom and Eboost ![]() Just got the engine in place to work out the engine and gearbox mounts ![]()
For Fathers Day I asked for some kid free time to work on the Mazda, so I got around to doing the old shorten shifter housing mod......
![]() Modified the gearbox cross member to suit the old RX4 one..... ![]() Made some plates to mount the engine off and exhaust manifold flange ......![]() ![]() Now I just have to install the engine and box and fab the mounts off the suspension crossmember. |
R/H side mount installed.....
![]() ...and L/H ![]() Getting there ![]() My latest purchase 60mm Tial waste gate and a GT42, ball bearing, water cooled A/R 1.06 exhaust. Now have to get in and make the exhaust manifold. ![]()
WOW! What a project you have there.
Very nice fab work on the engine mounts, but how come you didn't throw a gusset or two on the inside of the L shape on them? Looks like there's plenty of space for a few gussets, though maybe that'd be overkill given the thickness of material used?
And a GT42?! Wowzers, how much power are you planning to make?
Non Member
Trans mount really needs some rubber thrown in somewhere, or it's liable to have massive vibration issues.
Otherwise, awesome project. |
#9 |
Yea, it's now got a 10mm thick piece of rubber between the mount and gearbox bracket plus the crossmember is rubber mounted as well.
#10 |
A bit more forward progress.....
Got the pipe layout sorted, think it will flow ok ![]() ![]() ![]() Just got to sort out the transition piece on top Couldn't help myself and did a test fit in the engine bay ![]() ![]() ![]() Now have to have a think on how I'll plumb the wastegate. |
#11 | |
This is a great build you have going here.
#12 |
counting down till DGRR
Nice!!! keep up the good work!!
Cant wait for more updates!
-74 RX-4 -84 REW GSL-SE Past rides -05 REW Swapped RX-8 -93 FD base |
#13 |
Great build i like whene people put new tec on old school car,hay ma keep up the great work nice looking rx4....
#14 |
Finally got a few days to make this manifold
Tacked manifold to 25mm plate to help stop distortion...... ![]() Welded and turbo bolted on..... ![]() Fitted to engine to see how it fits. ![]() Now to fit the wastegate pipe! . |
#15 |
After a lot of thought decided to plumb the waste gate straight off the collector under the turbo.
I know it's probably not the best location for flow but there was really not enough room to run three separate runners. Here's the pipe tacked up....... ![]() ...and test fitted in engine bay. ![]() Pipe welded on and wastegate fitted ![]() And bolted onto engine ![]() Next is step is to send it off to get the mounting faces machined flat. |
| Tags |
| 20b, mazda rx-4 |
