Old 12-26-2009, 03:19 AM   #16
well, the water temp sensor is a biggie... you need to look into why it's throwing that code, if it's wiring, or if the sensor went bad. The rest of the codes are emissions components related. The boost pressure solenoid would normally be a problem, but since you have an aftermarket boost controller installed (correctly, I hope) it should not be an issue.
Old 12-26-2009, 10:01 PM   #17
Justen
In Too Deep
Justen's Avatar
Justen is on a distinguished road
So with the temp sensor fixed I'll be back in business. Great, so now I know i'm on the right track and didnt screww everything up lol. It was my first rebuild so i guess i was just a little paranoid. With an FPR i'll be ready to break the motor in in no time. Thanks for everything guys. As always, you really helped me out.
1990 TII, fresh rebuild
Atkins rebuild kit, RA apex seals
Med. Streetport, TB mod, rebuilt turbo, ported wastegate, GodSpeed FMIC
RacingBeat Turbo-back straight exhaust, Bonez test pipe, emissions/nest removed
hks intake, Walbro, Profec B spec-2
Justen is offline   Reply With Quote
