Old 12-07-2009, 06:03 PM   #16
Sweet!
I know that after I repainted the bay on my vert, and had to put all the stock CRAP back in there, I was really wishing that I could afford a standalone. I also absolutely despise how even the non abs stock brake line is routed, it's rubbish! This spring I am getting it redone for sure.
Old 12-08-2009, 07:54 AM   #17
-Six-
-Six- is on a distinguished road
Stand alone may also be in the works since I sold off my factory ECU...might as well upgrade.
-Six- is offline   Reply With Quote
Old 12-08-2009, 06:45 PM   #18
NoDOHC
NoDOHC's Avatar
If you just want to keep it from getting worse, I recommend POR-15. It is a little expensive, but it works well for stopping rust.
Old 12-08-2009, 09:29 PM   #19
nevermind.
Old 12-08-2009, 10:04 PM   #20
Originally Posted by Max777 View Post
nodohc, read my post above, there's better stuff out there then POR15.
Did I miss something?
I clicked the link and read that blog thing, and it looks like POR-15 was the winner?
Old 12-08-2009, 10:18 PM   #21
No, that would be me that missed something, lol. There was another article, and it made a lot more sense, and had eastwood as the winner, but I cant find it.... THAT article found eastood to be a lot more resistant to UV and such.... I'm looking for it now.
http://www.opelgt.com/forums/general...ust-encap.html
http://www.jalopyjournal.com/forum/p...ad.php?t=63136
quote from threads:
POR has problems with popping, shrinking, etc
the magazine that wrote it is not biased by any advertizing companies, it's kinda like consumer reports.
Old 12-08-2009, 11:04 PM   #22
-Six-
Thanks for the info Max, POR-15 was the one product I knew about, this is the first I have heard of Eastwood. Isn't the only sure fire way to deal with rust to grind it/sand it off completely, or would I still need to use a POR-15 type product?
Old 12-09-2009, 06:02 AM   #23
No, that would be me, lol. There was another article, and it made a lot more sense, and had eastwood as the winner, but I cant find it.... THAT article found eastood to be a lot more resistant to UV and such.... I'm looking for it now.
IMO, trying to seal off rust to make it "rustproof" is next to impossible.
The FC is not a museum piece, so I'm not looking for the "ultimate" solution.
With that said, I only have direct experience with POR-15.
I can't comment on the long term durability, but all I know is DON'T GET POR-15 ON YOUR CLOTHES, OR ANYTHING YOU DON'T WANT STAINED!
Anything porous, POR-15 will soak in, and you will never get it out, period.
So wear gear that you're going to throw away or don't mind getting stained.
In most applications, you really don't need to worry about UV exposure.
I've used it mostly in the engine bay or in the interior or under the car.
If you're going to use it on exterior panels, those panels would most likely be painted over with a paint???
I don't think "glowing" hot items under the hood would emit that much UV?
It's mostly IR, right?
I've seen the Eastwood (I'm on their mailing list) Rust Encapsulator, but I'm skeptical of their promises.
The original link we were talking about basically confirms my suspicions that RE isn't that great; I think if the metal were *totally* sealed, then RE might be superior - can you always guarantee your metal surface is totally sealed?
I'm glad that they did do a scratch test which shows real world applications when the coating seal is compromised.
So for the ramble, but for the OP...
The pics shows a lot of rust, but it does look only surface rust.
I agree that a quick blast with the wire wheel should take most of it off.
As for the rust up front at the round crossover tube...that's typical of most FC's I've seen.
Luckily that tube is not a load bearing piece, and it's only there for some clips for the wire harness and the oil cooler; it's designed to crumple on a front end collision too.
Old 12-09-2009, 03:50 PM   #24
BigIslandSevens
BigIslandSevens's Avatar
I've used POR 15 in most of my rust repairs( surface rust) Deep rust really needs to be removed and a patch panel made. For all my surface rust, I just did as Ted says. Take it down to bare metal with a wire wheel. Hit it with the POR 15 a couple times. Then primer and fill as needed prior to paint. I needed to fill a couple little pits that had formed from leaking acid.
I have not had any issues as of yet with the paint shrinking or popping. If you prepare the surface correctly, all the POR and filler should be sealed in with a final glaze to prevent any further absorbtion of paint materials.
And yeah POR stains everything. Takes a good month to wear off the skin.
Dave
Old 12-15-2009, 09:21 AM   #25
-Six-
Got my wire wheels and primer this weekend, still have to pick up some POR-15. Hoping to attack some rust this weekend.
