Old 11-18-2009, 03:09 PM   #1
93silverbullet
93silverbullet is on a distinguished road
Here's one for you guys
1993 FD with 69k on the chassis (except everything is pretty much new, inside and out).
Swapped in an '06 LS2 with a T-56 transmission with 3 documented miles on them.
  • 1-3/4" Stainless Steel custom JTR Headers - Ceramic Coated
  • 3" Stainless Steel exhaust into Borla XR-1 Racing Muffler (used as a mid-pipe) into a Racing Beat Dual Tip cat back
  • Ron Davis 3" thick Racing Radiator w/ Dual Fan Setup
  • 4" CAI
The suspension has been completely gone through:
  • Tein SS Coilovers with 8kg/6kg Springs
  • SuperPro Bushings (complete set)
  • Racing Beat Front & Rear Sway Bars
  • Mazdatrix Sway Bar Mounts
  • Rotary Extreme Toe and Trailing Links
  • Improved Racing Sway Bar End-links (front)
Pics:
93silverbullet is offline   Reply With Quote
Old 11-18-2009, 03:40 PM   #2
Holy crap clean swap
Old 11-20-2009, 11:12 AM   #3
93silverbullet
Thanks!
Old 11-20-2009, 02:51 PM   #4
need RX7
Clean S4 Nutswinger
need RX7's Avatar
Very very sexy . I remember reading your whole thread on V8RX7forum (I think it was there). I was very impressed by your attention to detail and quality of work. I've really been toying around with the idea of doing a V8 FD some day
Old 11-20-2009, 08:24 PM   #5
NoDOHC
NoDOHC's Avatar
That engine looks like it belongs in there. Great job! Nice car!
Old 11-23-2009, 08:14 AM   #6
lt1_fd3s
WNC Tour Guide
lt1_fd3s's Avatar
pretty...
Old 11-23-2009, 08:16 AM   #7
WoW! One of the cleanest LS I've seen! Great job!
Old 11-23-2009, 01:10 PM   #8
93silverbullet
Thanks guys! Its been a lot of fun doing this little project.
Old 11-23-2009, 01:47 PM   #9
dudemaaan
dudemaaan's Avatar
very nice. What kind of numbers does it put down?
Old 11-24-2009, 07:41 PM   #10
93silverbullet
The LS2 is basically stock with the exception of the CAI and the Exhaust as mentioned above. Here is the dyno chart from a recent event held at Corksports.
Thinking of a winter/spring project which involves L92 heads, a mild cam, and LS6 intake. This setup should be good for around 450 rwhp.
Old 12-04-2009, 11:52 PM   #11
/\ And that's all with a stock ECU or what? I did not see anything that mentioned engine managment.
If you can get 450whp out of an LS1 with an intake/ header/ exhaust, cam, heads, and not even tune it on top of it all, that is very impressive.
I wish I could bolt on a GT30 onto my 13b and not tune it.... that would be nice.
Old 12-05-2009, 12:28 AM   #12
NoDOHC
NoDOHC's Avatar
I have seen 360 WHp out of LS1 with different Cam, headers and stock tune. I don't know about 450 WHp on a stock tune, maybe out of an LS2. (Bear in mind that a Mass Airflow based N/A configuration will accommodate flow improvements very well).
Old 12-05-2009, 03:09 AM   #13
93silverbullet
The engine is an '06 LS2 using the stock GM PCM (which is programable). It is very doable to get 450 rwhp with the mods listed.
Old 02-21-2011, 12:25 PM   #14
zonblitz
zonblitz's Avatar
zonblitz is on a distinguished road
Richard always does things right. I followed some of the look of his last rotary build on my car. Now I'm following some of his good ideas on my LS build and he's been great with helpful info.
Thanks again Richard.
Kenny
If you need a website, or know anyone who does, look me up: www.efiniconsulting.com
zonblitz is offline   Reply With Quote
