Old 11-04-2009, 04:50 AM   #1
RHDJapan
RHDJapan is on a distinguished road
TRUST Informeter TOUCH released for FD3S!! Limited release!
Finally!, what everyone has been waiting for.
The Trust GReddy informeter TOUCH is now compatible with the FD3S! with the use of a special harness created by Trust.
more information can be found on our blog:
http://rhdjapan.com/rhdblog/blog/200...limited-offer/
they will only be making 200 of these.
-Chris
p.s. we can get these for you if you want
RHDJapan is offline   Reply With Quote
Old 11-04-2009, 05:01 AM   #2
How much are they and it says it will not work with aftermarket ECU?? I'm guessing PFC?
Also, what kind of info would this read?
Old 11-04-2009, 03:16 PM   #3
FDSeoul
it's smoking
FDSeoul's Avatar
FDSeoul is on a distinguished road
*Not compatible with vehicles running aftermarket ECU’s or ROM tuned ECU’s
FAIL once again!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
if it's smoking then it's working
FDSeoul is offline   Reply With Quote
Old 11-04-2009, 06:08 PM   #4
aaron_bc
aaron_bc is on a distinguished road
It may work with the PFC since it uses a lot of the stock sensors and such. If it dosen't, it's basiclly useless to anyone with an FD who is pushing any kind of power and woul dneed it (so would be running an a/m ECU)
aaron_bc is offline   Reply With Quote
Old 11-04-2009, 09:20 PM   #5
RCCAZ 1
RCCAZ 1 is on a distinguished road
So, I'm trying to understand any advantage of buying one? Can you use it to change or modify operating parameters, or is it just a glorified display??
RCCAZ 1 is offline   Reply With Quote
Old 11-08-2009, 07:26 PM   #6
jinxtacy
jinxtacy is on a distinguished road
*the item is hooked up via OBD II connector. If your vehicle does not have this the item cannot be used.
http://www.rhdjapan.com/jdm-low/Trus...nfometer-54045
jinxtacy is offline   Reply With Quote
Old 11-10-2009, 08:07 AM   #7
RCCAZ 1
So, I'm guessing this would be 95 only? Were the '94s and some 95s OBD II? Anyone know for sure?
Old 11-11-2009, 01:33 AM   #8
proz07
Needing a new tow rig.
proz07's Avatar
actually we cant use it if memory serves...... there was never an OBDII FD in the states that started in 96' and it was said to be too expensive to bring to the states so no 96+ for us among other reasons rumor has it
z
Old 11-11-2009, 07:28 AM   #9
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
Odbii
The cars in the states did not have OBDII ports. However the Diagnosis port should be available for accessing the same data. This is the direction I will be taking once my car is back up running. I will be installing a touch screen into the dash and hopefully with any luck will be able to interface to the Apexi ECu and Diagnosis port.
REVIT93RX7 is offline   Reply With Quote
