Instrument cluster illumination problem
Cluster stopped lighting up last night in the jack in the box drive through. everything else works, the fuse is good and when i tried to install a different headlight switch it started smoking . . . please help, need to see my gauges even if its a band-aid fix until i get the TII on the road. (s4 n/a)
1993 VR Touring, motor built by Arizona Rotary Rockets. |
Rep Power: 20 ![]() |
Check the wiring harness going to the headlight switch. If you burned up a 2nd headlight switch there may be a problem with the harness.
See if you can trace the burning wire back.. That might lead you directly to the problem.
Rat
1988 10th Anniversary 554 RWHP, 395 RW Torque 10.7 @ 126! owner: www.azrx7.com Engine built by ARIZONA ROTARY ROCKETS www.azrotaryrockets.com |
