Old 08-28-2009, 10:40 AM   #1
nvno1
FB 4life
nvno1's Avatar
nvno1 is on a distinguished road
:driving: Turbo Boost Gauge readings
Good Day All,
I was reseaching and not able to get a true understanding with Boost gauge reading.
I have a aftermarket boost gauge and wanted to know what it should read vs what i am getting to help with some troubleshooting. At what Rpms should the Hg be in and when does it go to possitive numbers. Meaning when does the needle on the gauge leave the -Hgs and goes into the measurable boost numbers?
I know it seems like i'm, however i cant find anything concrete on this matter.
Thanks in advance,
SJR.
Dont be sorry, be careful.
nvno1 is offline   Reply With Quote
Old 08-28-2009, 10:58 AM   #2
dudemaaan
dudemaaan's Avatar
Hg " is vacuum you will see this at idle and off throttle. Anywhere from 14-20"hg, depending on your porting. Positive pressure will start as soon as you step on the gas and the turbo begins spooling. For stock twins you should see 10psi by like 2k rpms with a small dip to 8 psi at 4k rpms and then right back to 10 psi. Single turbos will just depend on their size. Some gauges read in bar, in which case you will have to convert my psi measurements.
Old 08-28-2009, 11:49 AM   #3
nvno1
FB 4life
nvno1's Avatar
WOW thanks for the prompt response. Well the car is a 87 TII,stock motor, RB downpipe and walbro fuel pump. The gauge reads in PSI, my gauge doesnt go that high. Well she is not on the road yet(no driveshaft right now).
Old 08-28-2009, 12:14 PM   #4
you won't build boost in neutral....with stock injectors you should not see more than 10 psi but, like I said, you won't build boost without load.
Old 08-28-2009, 01:24 PM   #5
nvno1
FB 4life
nvno1's Avatar
Smile
great, however what should the Hg be at 750, 1000, 1300?
Old 08-28-2009, 04:42 PM   #6
Vacuum reading don't really matter except for maybe at idle.
When driving, when you see vacuum on the gauge, it just means the turbo isn't working to produce boost.
Trying to see your vacuum numbers while driving is a royal waste of time.
Old 08-31-2009, 09:20 AM   #7
nvno1
FB 4life
nvno1's Avatar
Wow Ted, i feel so honored you replied on my post. I'm not driving the car right now, my main reason for asking about the vaccum is the idle is not set and i wanted to know if at 1000rpms, if the reading is right? I have checked for vac leaks and nothing has surfaced, however i dont have another way of verifing there is no leak. So i figured the vac reading on my boost gauge would fall as a back up.
Old 08-31-2009, 11:03 AM   #8
Ah, the mysterious missing vac leak, where you know you have one, but just can't find it.
Try to get a smoke machine. That should show you exactly where your vac leak is. I am in the process of doing this, but have a few things to do first before I do (mainly earn money).
as for boost and vac readings. Are you sure your gauge is grounded properly? Not having a proper ground will give you very messed up readings. If you have, expect to have anywhere from 14-20+inHg in vac. I'm currently pulling in around 14inHg on a fresh rebuild (though compression is absolutely fine). Good luck though.
Old 09-02-2009, 04:37 PM   #9
Flooder
Flooder's Avatar
Flooder is on a distinguished road
Sure you will, just not very much. You can still make your BOV vent when in neutral.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 09-03-2009, 11:22 AM   #10
nvno1
FB 4life
nvno1's Avatar
matter of fact it did...my boost gauage hopped up to nearly 5psi. it was pretty cool to see.
Old 09-11-2009, 01:00 PM   #11
nvno1
FB 4life
nvno1's Avatar
low Hgs.
OkAy SOoooo...like my Hg rading are low..i got video coverage of the issue, no dvd player on the wk pc and dont have internet access else where right now. so what i decided to do is block everything off with block off plates, get another BAC, change all the remaining hoses, upper to lower intake gasket and check the fuel injectors. from the information you guys have given me the Hgs are to low. i am sure that it HAS to be a vac leak somewhere. oil pressure good, not getting hot, no bubbling at the rad, no sweet smell out exhast, and hard to start unless i play with the trottle.
Old 09-12-2009, 08:29 PM   #12
I doubt that's the case.
I put money it's something else.
Other causes that can "fool" your boost gauge to show improper vacuum while driving:
* ignition problems
* fuel delivery problems
* misfire
* hurt motor
Old 08-28-2009, 10:50 PM   #13
NoDOHC
NoDOHC's Avatar
I think a stock ECU rotary should run about -15 to -18 "Hg at Idle. As you gently rev the engine in neutral, this will dip a little about 1200 rpm (-18 to -21), but remain relatively consistant after that.
With an aftermarket ECU I run about -15 " Hg when cruising on the highway and about 21 " Hg at idle (Timing advanced over stock).
Old 08-29-2009, 03:12 AM   #14
dudemaaan
dudemaaan's Avatar
Ignore what i said about 10 8 10 boost, thats for 3rd gen rx7's with sequential turbos. Didn't think about it being a 2nd gen. I wouldn't worry too much about vacuum provided you have good compression numbers. But stock ports usually pull over 16". My large street port pulls around 15" at 1000 rpm.
Old 08-31-2009, 09:24 AM   #15
nvno1
FB 4life
nvno1's Avatar
, Yeh i was still looking around and nothing seems very concrete on the matter on hand. I was just trying to see if there was a leak(still havent found any) and having low vac reading would state a vac leak right if the compression, fuel pressure and ignition is good right?
