Old 08-17-2009, 09:11 AM   #1
Oldguy
Oldguy is on a distinguished road
need brake lines
I am new , having trouble navigating site. Does anyone know if you can buy brake lines already bent to shape for an 88 non turbo RX 7. Thank You
Oldguy is offline   Reply With Quote
Old 08-17-2009, 05:55 PM   #2
Only dealers have such a part.
Finding a set from a junked chassis probably is easiest and cheapest.
Check out the classifieds sections for people parting out whole cars.
Else and "brake shop" can custom bend you a set.
Parts are relatively cheap, and a tube bender is a cheap and simple tool.
The flare tool is a bit more expensive, but any shop that does brakes all the time should not have a problem.
Old 08-17-2009, 10:22 PM   #3
NoDOHC
NoDOHC's Avatar
You can buy pre-cut lines and bend them with your thumbs to match the rusty lines. It will probably not cost you more than $30.00 to replace all the rear lines.
I don't understand how the brake lines on RX7s can rust out, I have two with factory lines on them that are completely rust free (still coated with the polymer coating).
My '90 has rusted brake lines so I know that they do rust, but I don't know how when they are protected inside the polymer coating.
