Old 06-22-2009, 10:56 PM   #1
Do your coolant temps and AIT's a favor
Plug the exhaust port passages in your housings. Recently I rebuilt a motor and the ONLY thing that I changed, aside from the seals and the housings, was to plug the exhaust port passages in the housings. In my case, they were RE housings and have a HUGE port with an insert in them. I first tried tapping the insert for 1/4" NPT but the insert started spinning. So I drove that out and tried for 3/8" NPT. No dice as the housing would have to be machined. Instead what I ended up doing was taking my plate of 3/8" 5052 aluminum and cutting out something that resembled a circle of about .6". Then I spent a fair amount of time hand fitting it to .550" with a slight taper in it. I then drove that mother into the passage blocking all the exhaust gas from making it's way through the housing, into the LIM which, obviously, has the ACV & EGR passages blocked. I was quite proud of those little pieces. Here they lay
So, what was the result. Sadly I cannot speak intelligently on the AIT's as I'm measuring them pre-TB. Coolant temps however......... mine are retarded to begin with, generally they were around 174-175* on the highway and never getting above 187*. They are consistantly 4* colder and the ambient temp has risen about 10* on average. All that from blocking the little f'n port underneath the exhaust sleeves. I will NEVER build another motor with these things left open.
Old 06-23-2009, 07:32 PM   #2
glenrx7
glenrx7 is on a distinguished road
We have done this with our engines for sometime now however never had the right circumstances to see what the results were I knew it helped however never had the chance to see how well. Nice job!
glenrx7 is offline   Reply With Quote
Old 06-26-2009, 12:12 AM   #3
Thanks Glenn. I wish I could see what the difference was in the AIT's though. My thinking is it would be a higher percentage drop than the coolant temps.
Old 07-22-2009, 02:47 AM   #4
sen2two
KTEC
sen2two's Avatar
nice job!
ever think of welding it shut or using an epoxy? i dont know of any epoxy that could withstand 1600+ degrees though...
what I have:
What I had:
