Old 06-06-2009, 09:23 PM   #1
misterstyx69
.drives like MrMagoo!
misterstyx69's Avatar
misterstyx69 is on a distinguished road
.Want to wire FD TPS onto the FC wiring.(how?).
I am "attempting" to put an FD upper on my FC TII and I need to know How to Wire the FD TPS onto the Harness.I have the TPS Connector.
another quick Question: I am running RTEK 2.1. Can I run the FD TPS with an RTEK?.or should I just Say Frigg It,and Put on the TII upper and wait until I get a Haltech?Thanks Gents.STYX.
misterstyx69 is offline   Reply With Quote
Old 06-07-2009, 03:23 PM   #2
TehMonkay
FC ecu does not use a full range tps for anything other than MOP operation on the S5, and the TPS on the fd is full range. I'd guess you're not going to have alot of luck with it though it MIGHT work if the ohm range is the same between the two which you could test for with a DMM or check in the FSM.
As for wiring, you'll need to look that up in the fsm as well. Just match up the wires, one is +5v, one is ground, one is for the sensor output.
Old 06-07-2009, 06:06 PM   #3
antman0408
antman0408's Avatar
antman0408 is on a distinguished road
I thought the fd tps had both a full range and narrow range, so it could be wired on both the s4 and s5. I think this is way to wire it on an s4
FD tps S4 harness
ground - black/brown ---- brown/black
narrow tps- green/red ------ green/red
5 volt ref. - brown/white ---- brown/white
tps - black/green ----- not used
antman0408 is offline   Reply With Quote
Old 06-07-2009, 06:58 PM   #4
misterstyx69
Thanks Tony..I'll meter that out and see what I get.I just got the Stuff together(parts wise,not assembled).I don't want to put it on Unless it is Runnable with what I got.Otherwise it becomes this Winter's Project!.I am making my OLD N/A engine into a TII engine,and I think that is gonna have the FD upper on it..maybe have a T4 Turbo too!..haha..Should be Quite the engine(for about 10 minutes!).Cheers Lads.Keep the info Coming..
ARGHX where are you?(info!)..Cheers,STYX!
Old 06-27-2009, 02:30 AM   #5
sen2two
KTEC
sen2two's Avatar
i wired my my S5 tps to the FD tps. i have the FD upper on my FC. i cant remember wich goes where. but i could check tomorrow and let you know. its pretty easy though.
what I have:
What I had:
