Old 04-18-2009, 09:24 AM   #1
proz07
Needing a new tow rig.
proz07's Avatar
When idler pulley bearings fail!!!
Hey guys just like to let ya know new parts fail too!! I purchased the tweakit single turbo air pump removal idler pulley in the group buy. I put it on sunday and drove maybe 70 miles seeing the entire rpm range including redline. it failed 1/3 mile from my house conveniently. Im sure its not a defect in the part by anymeans a very well put together product but i believe i got a bad bearing with it.
The bearing is McMaster Carr # 2349K471 for $18.16
possible ALT----honda #96150-60020-10 $7.xx average ebay 2x $3.95 + $8.75ship (this is a lawnmower bearing)
i checked he specs on it and it is well within spec at any rpm range with the stock main pulley it comes out close to 15,3xx rpm at 8K redline. The specs for the bearing are:
Maximum rpm
19,800
Maximum rpm Range
15,001 to 30,000
So its obvious there is NO DESIGN FLAW just a manufactur defect from the bearing company
havent heard back from chadwick yet on this but at least we know where to get the replacment bearing. as per install instructions reference
Well heres the carnage:
Old 04-18-2009, 09:42 AM   #2
Holy shit! I'm glad you caught it in time and didn't overheat!
Old 04-18-2009, 11:11 AM   #3
Brent
Sua Sponte
Brent's Avatar
I'm sure Dan will get back to you shortly. He's currently at DGRR.
Old 04-18-2009, 11:51 AM   #4
proz07
proz07's Avatar
ya i figured as much thats cool
thanks
z
Old 04-21-2009, 05:04 AM   #5
Spindoctor
Spindoctor's Avatar
Spindoctor is on a distinguished road
I spent a few years in the automotive accessory drive industry. While there are various types of bearing failure and none are immune to manufacturing defects, a great deal of emphasis is placed on proper press-fit tolerances. Depending on the service conditions, Loctite is often used in favour of an interference fit. Excessive interference or some initial damage during assembly will eat a bearing up in no time....as will the type of seal and grease compatibility with the application.
Spindoctor is offline   Reply With Quote
Old 06-20-2009, 11:11 PM   #6
proz07
proz07's Avatar
update:
if ya didnt know tweakit has gone back to the original pulley bearing from the regular kit and so far i have had no issues 60miles and still kicken ill up date more later. they definatly stand behind thier work i personally went through 3 bearings till they went to the original pulley kit bearing to the one from the single. so far so good two thumbs up to tweakit!
z
Old 06-21-2009, 12:20 AM   #7
bencb44
bencb44 is on a distinguished road
Is it just me, or is your idler pulley for the P/S, A/C belt on backwards?
bencb44 is offline   Reply With Quote
Old 06-21-2009, 10:44 AM   #8
proz07
proz07's Avatar
yes it is or at least i think but i am missing/bearing worn something cause flipped it it rubs the bracket. is just an idler and works right now but i definatly need a new one or replacment bearing cause it is loud! un fortunatly no body even has it listed so right now it works so ill figure somethin out later
z
Old 07-16-2009, 05:26 PM   #9
somchhir1
The boosted the better...
somchhir1's Avatar
somchhir1 is on a distinguished road
My pulley has less than 150 miles....and has started leaking oil out of the seal.....
04 GT Yellow Mica RX-8-sold
93 SSM FD-sold
94 SSM FD-Sold
somchhir1 is offline   Reply With Quote
Old 07-17-2009, 08:03 AM   #10
SPICcnmFD
SPICcnmFD's Avatar
Is it the new bearing or the old bearing? If it's the old send the pully back and get it replaced, I still need to do this. Mine made it to the track after I installed it and then died right after I got on track, looks just like the pictures above. It's alittle nerve racking when you have an engine with about 3k on it and you hear a noise look down and the dash lights are on and the temp starts to shoot up.
1993 Rx-7 SM2 #11
At the local AutoX:
http://www.youtube.com/watch?v=9VOSQkkSLQs
Speed for Sale shootout 2007:
http://www.youtube.com/watch?v=JiqlyAkGmpg
A few laps at Barbers:
http://www.youtube.com/watch?v=6_h5q...x=0&playnext=1
Old 07-17-2009, 10:54 AM   #11
somchhir1
somchhir1's Avatar
Couldn't tell you....I won it at DGRR....here's a pic
93 SSM FD-sold
94 SSM FD-Sold
Old 07-17-2009, 11:01 AM   #12
Chadwick
Chadwick's Avatar
Chadwick is on a distinguished road
That looks like the normal amount that spins out when the bearing is first installed, by the color it would suggest that it has been there awhile, wipe it off and run it until the motor gets hot and check it again. If it is still leaking, we will replace the bearing.
Thanks,
Dan
93 RX7 BB (Race Car)
93 RX7 SSM (Soon to be IBM and a daily driver)
05 Silverado Z71
08 Mini Cooper
80 LS RX7 (for sale)
Chadwick is offline   Reply With Quote
Old 07-17-2009, 11:03 AM   #13
somchhir1
somchhir1's Avatar
Thanks,
Dan
will do...thanks...it might take a couple of weeks to do...still waiting on other parts to come in.
93 SSM FD-sold
94 SSM FD-Sold
Old 07-16-2009, 05:36 PM   #14
Leaking from the seal? Bearings do not hold 'fluid' and is not a totally sealed unit.
And excess grease inside the bearing from initial build will eventually weap out.
Old 07-16-2009, 06:16 PM   #15
somchhir1
somchhir1's Avatar
then i hope that's all it is...thanks
93 SSM FD-sold
94 SSM FD-Sold
