Old 04-05-2009, 05:37 PM   #1
townidiot
townidiot is on a distinguished road
turbo2 drive shaft problem
im in the middle of putting a s5 turbo motor into my s4 turbo rx7. and today i tried to install the drive shaft, but for some reason its to long.(its a s4 drive shaft) so my question is do i have to get a s5 drive shaft or do i have to cut the s4 to fit?????
-thanks
townidiot is offline   Reply With Quote
Old 04-05-2009, 06:06 PM   #2
If you are using the S5 trans, you have to use the S5 driveshaft.
Basically, it is isn't the engine, its the drivetrain that needs to stay in the family (S4 or S5) trans->driveshaft->differential
From what I have read, you cannot mix and match pieces.
Old 04-05-2009, 06:51 PM   #3
townidiot
so the differential also has to be s5
Old 04-05-2009, 07:32 PM   #4
That is the information I got long ago. From what I understand, the only thing that is usable in the drivetrain between S4 and S5 TII's are the axle shafts.
I would hope someone else can chime in.
Old 04-05-2009, 07:43 PM   #5
EJayCe996
PPP-P-P-P-POWER!
EJayCe996's Avatar
EJayCe996 will become famous soon enough
I'll go verify the diff right now, I have an S5 TII Trans, driveshaft,and an S4 TII rear end.
*the holes line up, but i don't have any spare bolts on hand
1. Walk through a row of 22", or larger, rims
2. Say you love dubstep
3. ?????
4. PROFIT!
Axiomatic: Total cacology.
EJayCe996 is offline   Reply With Quote
Old 04-06-2009, 07:55 PM   #6
Flooder
Flooder's Avatar
Flooder is on a distinguished road
That's weird, I've never heard that before.
AZRX7.COM
Red 1991 A-package(SOLD)
Red 1990 GXL(SOLD)
White 1989 GTUs(DEAD)
Red 1988 Turbo II(DD)
Black 1988 Turbo II(SOLD)
Rebuilt and street ported motor, Garrett T04E Turbo, 3" Turbo Inlet Duct/AEM Dry Flow Filter, Your Mom's MBC, Blitz FMIC, 890cc and 1000cc injectors, Tomei FPR, Walbro, Rtek 2.1 ECU, Taurus E-Fan, Turbonetics BOV, 3" Motoria/Corksport Turbo Back Exhaust, Emissions Removed, Greddy Boost Gauge, Megan Racing Water Temp Gauge, 5one5 Triple Gauge Pod, AEM Uego, GP Sports Body Kit, Fiber Images CF Hood, S5 Seats, S5 Tails, S5 Alt, Dual Alt Pulley, D2 Coilovers, NRG Quick Release, Shook Motorsports Radiator, HID's, AN/Steel Braided Oil Cooler Lines, SUPER JDM TYTE DRIFT BUTTON
www.DensetsuMotorsports.com www.AZRX7.Com www.FloodersAdventure.com
Flooder is offline   Reply With Quote
Old 04-06-2009, 08:43 PM   #7
Um, your forum name makes me want to state the obvious so don't be offended:
Your putting the transmission end first, right?
Now, the automatics ALL use the same DS. The rest are series specific with their pumpkins. How much longer is it?
Old 04-07-2009, 01:46 AM   #8
Flooder
Flooder's Avatar
Yah, you have to put the transmission end of the driveshaft in first then bolt it up to the differential.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 04-08-2009, 05:18 PM   #9
townidiot
yes i put the transmission end in first and its about 3 inches long.i messured it and i think it was 41" how long is the s5 if anyone would know...
Old 04-08-2009, 06:02 PM   #10
Are you sure that you put the shaft all the way in, and that the trans or the diff is REALLY from the turbo model?
I have never heard that the Trubo stuff has to be series specific either, and I trolled the evil forum for like 2 years before I got my fc.
I guesss you really DO learn something new every day!
Old 04-08-2009, 06:24 PM   #11
townidiot
yep i made sure i put it all the way in.and yes they are both turbo trans and diff.
Old 04-09-2009, 04:41 AM   #12
Turbo doesn't matter - they should all swap.
This is not some funky JDM automatic FC turbo driveshaft, or something weird like that, right?
The rear diff have different bolt patterns for turbo versus non-turbo.
Tried checking the bolt pattern on the rear diff side first?
Lastly...
Is the engine + trans mounted and bolted into the car already???
Old 04-08-2009, 10:25 PM   #13
Flooder
Flooder's Avatar
Just doesnt make sene to me. I dont see how or why it would be different. You probably have an NA rear end.
AZRX7.COM
Red 1990 GXL(SOLD)
Old 04-10-2009, 04:17 PM   #14
townidiot
yes its a turbo rear,yes the bolt pattern matches, it has a lsd if that would do anything, this used to be my friends car he gave me the drive shaft with it. that he used with his s4 turbo motor,and yes the motor and tranny are both bolted in.
Old 04-10-2009, 04:19 PM   #15
townidiot
i bought the motor from a importer, would there be a diference with how far the tranny sits back when it comes to jdm to usdm????
