Old 03-06-2008, 09:38 PM   #1
$100T2
Big Daddy
$100T2's Avatar
Sterling...
How do you modify the Nikki? Not a step-by-step thing, I mean what changes do you make to it? And, since I'm pretty clueless about carbs, can you explain a bit of carb theory???
Old 03-06-2008, 09:48 PM   #2
rx7carl
rx7carl's Avatar
rx7carl is on a distinguished road
His site has a good explanation of the modded nikki.
Hope this isint too simplistic of a basic explanation.
http://static.howstuffworks.com/mpeg/chainsaw3.mpg
Accompanying article
http://auto.howstuffworks.com/question377.htm
www.pbandjracing.com
rx7carl is offline   Reply With Quote
Old 03-09-2008, 09:49 AM   #3
warwickben
sa rat rod
thats a good way to tell how a carb works. it works on the same idea of a vacuum(is that right sp?) hold down for a mill.
you have a T in a air line the air flows at the top of top of the t and it pull air from the bottom of the T causing a vacuum effect. but on a carb it pull's gas in to the motor.
Old 03-09-2008, 12:55 PM   #4
Sterling
Premium Vendor
Sterling is on a distinguished road
Pretty much.
It's called the "Venturi Effect", and it was first quantified by Daniel Bernoulli in the 18th century. Giovanni Venturi, a generation or so later, is credited with developing apparatuses to harness that pressure differential that occurs; Hence the "venturi".
Venturis are used for everything from carburetors to nuclear power plant cooling towers.
Sterling is offline   Reply With Quote
Old 01-30-2009, 10:34 AM   #5
orion84gsl
Are you getting a modded Nikki or a Sterling. They are different.:P
Old 02-01-2009, 07:29 PM   #6
Kentetsu
Kentetsu's Avatar
I don't believe Carl builds carbs. I think he did a lot of the R&D work along with Sterling, but the carbs are all built by Sterling. Yaw has been out of the business for many moons now.
Old 02-03-2009, 01:18 PM   #7
csprx7
csprx7's Avatar
csprx7 is on a distinguished road
Carl did. I have one on my '85 (was on my now departed SA).
Geo.
1985 RX-7 ITA/CSP
1985 Ford E150 Club Wagon (Tow)
2004 Mini Cooper S
csprx7 is offline   Reply With Quote
Old 02-03-2009, 09:31 AM   #8
Sterling
Premium Vendor
Yep. Yaw's out. I wish I knew what that guy knows.
Old 02-11-2009, 09:01 PM   #9
orion84gsl
Better get your order in quick before Dennis gets too swamped. It's not an overnight deal, but it's worth the wait.
Old 11-12-2009, 06:40 AM   #10
Sterling
Premium Vendor
The return orifice in the inlet banjo bolt must be blocked.
What kind of pressure are you putting through there?
Old 11-12-2009, 08:53 PM   #11
Sterling
Premium Vendor
-What the level in the fuel bowls? It's very strange to see that.
Old 11-12-2009, 09:12 PM   #12
Sterling
Premium Vendor
...I honestly can't even understand how that can happen. Basically the only way that can happen without the bores filling up is that all four fuel circuits would have to be completely blocked.
Old 11-14-2009, 05:30 PM   #13
rx7carl
rx7carl's Avatar
Is there also fuel dribbling out of the nozzles into the barrels?
Old 11-21-2009, 11:31 AM   #14
rx7carl
rx7carl's Avatar
Sure, it could simply be sticking floats. Happens all the time to carbs I've shipped. Tapping on the banjo bolts while the fuel pump is running usually unsticks them.
Old 02-05-2010, 02:56 PM   #15
Kentetsu
Kentetsu's Avatar
Have you tried asking Sterling? Either email him, or go to his forum. He keeps telling people that, but I keep seeing these threads pop up....
