Rep Power: 21 ![]() |
Can anyone name the wheel?
I found this on an SA at a local salvage yard. but it doesn't look like the typical SA alloy to me. Was it one of the optional wheels?
For current updates and event coverage check out Follow on Twitter! @WhizbangRally Whizbang Rally's Webpage | Facebook Last edited by Whizbang; 02-22-2009 at 09:53 PM. |
that is a nice wheel... hopefully some one knows what it is..
figured it out, 1979 Limited. I have two, going to have to go back for the other three (had a nice full size spare). Turns out they are the rarest of the rare for US model wheels.
#4 | |
Rotary Nut Case
Rep Power: 17 ![]() |
I also have a couple of set of ALMEX rims I think that they are the best looking of the SA rims personally, also they are very similar to the rims that came on the 77-78 cosmos |
Yep LE wheel
I own A few Rotaries and Yes, I have a rotary problem. (SELLING OFF All my parts) 79SA(Respeed Car),93 FD (tweakit) |
is that the famous ALMEX wheel?
![]() www.rx7club.com.ar RX-7 Forum in Spanish I make custom decals. Yes, you can ask me |
negative.
This is the almex
the spare was beyond rotted. the car itself is actually almost gross to work around. under in the woods for the better part of 10 years... but it was a bridgestone. i still *think* i have it. it might not be THAT bad, but for sure not good. I can see if the other SA has its spare. Its in WAY better shape
#9 |
Rotary Nut Case
I would be interested in any SA full sized Bridgestone spares those are the ones I use for restos since no one makes them and they are hard to find.
I don't drive one them they are for display only. |
#10 |
yea ill take a look for you then
#11 |
You are right those are the LE Wheels. A friend of mine used to have a set.
#12 |
Rotary since 1972
That guy would be the 9965-21-5530
Here is what my 1983 fiche shows: Wheels RX7 79/80 37600 D-CODE WHEEL,DISC JANTE 9965-11-5030 DESIGN WHEEL 5.00 JX13 WDC SUNBEAM METALLIC K3 SILVER METALLIC 08 9965-18-5530 ALUMI, WHEEL NKK MAKE 5.50 JJX14WDC 9965-21-5530 ALUMI, WHEEL YOKOHAMA MAKE LIMITED 5.50 JJX14WDC SA22C- 542637-552248 9965-22-5530 ALUMI, WHEEL YOKOHAMA MAKE 5.50 JJX14WDC SA22C- 5531149- *9965-23-5530 5.50 JJX13WDC ALUMI WHEEL GOLD 80 MODEL SA22C 606775- * COULDN'T FIND ON MY FICHE WHAT IT WAS REFERENCING |
