Old 02-19-2009, 12:29 AM   #1
91convguy
91convguy's Avatar
91convguy is on a distinguished road
My cheap Manual is not showing me anything.
My Rx has developed an oil leak at filter body see the two little O rings in the book but not sure how to replace them. I remember replacing them on my 83 Rx, it had oil cooler right there under filter it was pretty straight forward. Looking at diagram can't figure out how it comes apart. Someone help me out here.
91convguy is offline   Reply With Quote
Old 02-19-2009, 12:36 AM   #2
JL1RX7
Where are you talking about at the pedestal right under the oil filter? or under that?
Old 02-19-2009, 12:43 AM   #3
there are two, i believe 10mm nuts that hold the oil filter pedestal onto the rear iron. They are located on the underside. As you stated, there are two equal size o-rings underneath. Directly below that is the oil pressure sender which also could be the source of your leak if the pedestal o-ring replacement does not fix the issue.
Old 02-19-2009, 04:51 AM   #4
91convguy
91convguy's Avatar
Thought it would be simple the book I have does not even discuss this issue witch is a little odd. Know this is the problem, last oil change I always double check filter make sure no leaks noticed oil seeping between pedestal / iron. The only thing that going to suck about this fix is the limited room around it. Thanks for you help!
Old 02-19-2009, 11:27 AM   #5
TehMonkay
yeah two 10mm nuts on the bottom of where it mounts on the iron, make sure to order orings first my friend could not find any locally.
