Old 02-08-2009, 10:04 PM   #1
hades
brake caliper rebulid & paint
I am rebuilding my brake calipers. Anyone know a good paint to use? Dupilcolor has both 500 and 1200 degree paint. Any others?
This is going to tear
Old 02-09-2009, 12:13 AM   #2
Kwerks
FD Spirit
Kwerks's Avatar
Kwerks is on a distinguished road
I'v used the 1200 paint in red before but it chipped off after 2 years and its still chipping off...I'm thinking of powder coating mine.
Understeer is when you hit the wall with the front of the car and oversteer is when you hit the wall with the rear of the car.
Horsepower is how fast you hit the wall, torque is how far you take the wall with you.
Kwerks is offline   Reply With Quote
Old 02-09-2009, 08:22 AM   #3
GreatShamanGT
GreatShamanGT is on a distinguished road
I used the 1000 degrees on a downpipe and that stuff burned off at around like 300 degrees. I think it only works when it's at 1000 degrees
GreatShamanGT is offline   Reply With Quote
Old 02-09-2009, 09:10 AM   #4
Garfinkles Motor Works
I had mine powercoated dark gray and the rotor top hats done in silver after I cross drilled them .The car is silver .
Old 02-12-2009, 09:14 PM   #5
Signal 2
Viable Fossil
Signal 2's Avatar
I used the Dupli-color caliper paint and it works just fine. Like always, prep is everything. I think anything over 500 F. would be overkill on a caliper.
GreatShamanGT, FWIW I used DEI's header paint/coatings on the downpipe. It blushed a little the first time with the heat, but looks fine, and adhesion has been great. IIRC, good to 1500 F.
Jim
VR R1 FD
Old 02-13-2009, 01:30 PM   #6
prrex4ever
prrex4ever's Avatar
I used the kit that "Tire Rack" sells and so far so good. Can't remember the name brand but I believe it's a German company.
Old 02-13-2009, 01:55 PM   #7
Kane
All about the O2
Kane's Avatar
Kane is on a distinguished road
I used the caliper kit - it is ok; but powdercoating is the real way to go.
My 2007 Turbocharged RX8
Kane is offline   Reply With Quote
Old 02-13-2009, 07:34 PM   #8
hades
i have the front calipers pretty much ready to go. Took a wire wheel, wire brush and simple green to them. Repeated rinsing with brake cleaner.
I will probably just use the duplicolor 500 degree paint. I just want to be able to do this job once. I have all my parts in hopefully I can get the fronts rebuilt and on the car this weekend. I am also removing my dp, replacing the belts, plugs, installing my temp sending unit, o2 sensor, trans fluid, diff fluid, and fuel filter. Doubt this will all get done--I need my beer drinking time too.
Old 02-13-2009, 08:13 PM   #9
prrex4ever
prrex4ever's Avatar
I agree, I guess it depends on how much money, time and effort you want to put into it at that moment . Whenever I have to replace or rebuilt mine that is the route I plan to take.
Old 02-22-2009, 07:24 PM   #10
hades
I just tried the brush on Duplicolor paint. My brother bought some years ago and we never used it. I thought I would give it a try-I didn't like the results so I took it off. I am going to call about powder coating, but I don't want to spend an ass load right now.
Old 02-22-2009, 07:47 PM   #11
apparently model car paint works well.
Old 02-22-2009, 08:39 PM   #12
Caim
Caim's Avatar
Caim is on a distinguished road
^ lol, yeah check out my thread .... project forever... That will show you what we use and it is great. Never chipped off for us.
Caim is offline   Reply With Quote
Old 02-23-2009, 10:23 PM   #13
I used the duplicolor brush on paint... the fronts were new remans, and the paint went on fine, but the rears were old, and even through I scrubbed them, they did not turn out that great. I think if you use caliper paint, use the spray can for this job!
Old 02-23-2009, 11:00 PM   #14
hades
I went a head and sprayed them. I am required to take time of work so I am taking a trip to see some friends. I may get another set of calipers in the future and power coat them.
Old 02-24-2009, 12:36 PM   #15
REVIT93RX7
REVIT
REVIT93RX7 is on a distinguished road
Brake Caliper
There are a number of aftermarket companies that rebuild the calipers that also provide them in numerous powdercoated colors. I did this for my rear ones, it was actually cheaper to buy them rebuilt and coated then it was to buy the necessary parts and rebuild them myself!
REVIT93RX7 is offline   Reply With Quote
