Old 01-31-2009, 05:42 PM   #1
ObliqueFD
ObliqueFD's Avatar
ObliqueFD is on a distinguished road
How much does a manual transmission weigh?
I've heard it weighs from 90 lbs. to 125 lbs. Obviously it's going to vary based on the components bolted on. Anybody know?
'93 SSM RX-7
'93 BB RX-7
'04 BB RX-8
ObliqueFD is offline   Reply With Quote
Old 01-31-2009, 05:49 PM   #2
Doc-1
Doc-1's Avatar
Doc-1 is on a distinguished road
It is less than 100 lbs I have one how important is it to know, The starter and bell housing put it about 100 or so
Doc-1 is offline   Reply With Quote
Old 01-31-2009, 05:52 PM   #3
ObliqueFD
ObliqueFD's Avatar
I was just curious if the one I plan to buy could be shipped via Greyhound. They have a 100 lb. limit. Thanks.
'93 SSM RX-7
'93 BB RX-7
'04 BB RX-8
Old 01-31-2009, 05:59 PM   #4
Doc-1
Doc-1's Avatar
Keep the bell housing and starter off you should be okay
Old 01-31-2009, 06:09 PM   #5
David Jerome
David Jerome's Avatar
You would likely be better off shipping it freight via www.gorlc.com. Will cost about $85-125.00 depending where you are shipping to.
David Jerome
Old 02-01-2009, 09:39 PM   #6
dregg100
i recently shipped a turbo II transmission via fedex and it was only $55. i know the fd tranny is a bit heavier, but its worth a shot.
'93 SSM Touring-S475...
'87 Tii-LS1/T56
Old 02-02-2009, 10:09 AM   #7
David Jerome
Did you use freight or box it? Because that is an awesome price, let me know as I always like saving money with all the shipping I do.
David
David Jerome
Old 02-04-2009, 10:03 AM   #8
dregg100
David
yep, just a box and packaged it well.
'87 Tii-LS1/T56
Old 02-01-2009, 11:23 PM   #9
Signal 2
Viable Fossil
Signal 2's Avatar
Stock FD 5sp transmission dry = 112 lbs. w/o bellhousing = 90 lbs.
Jim
VR R1 FD
Old 02-02-2009, 01:31 PM   #10
Force Fed
Force Fed is on a distinguished road
I've had good luck w/ UPS, I shipped a A-833 OD 4-spd out of a Dodge truck to Texas for 108, the cardboard box was trashed but the trans made okay I think it weighed like 125 or something.
Force Fed is offline   Reply With Quote
Old 02-03-2009, 03:27 PM   #11
Prometheus
Prometheus's Avatar
Prometheus is on a distinguished road
Make sure it is packed properly.
The spline is about 3mm proud (longer) than the bell housing.
Get a piece of plywood, get a drill
Bit that matches the width of the spline and counter sink it by a 1/4"
Now set the spline in the recessed part of the plywood.
The bell housing should lay flat.
Trace the outside of the bell housing.
Cut the plywood and hold it up to the tranny.
Drill holes and install some shipping hardware, to keep the plywood in place.
That is how pineapple ships out their rebuilt trannies. (to prevent damage to the synchros)
Prometheus is offline   Reply With Quote
