Go Back   Rotary Car Club > Vendors and Group Buys > All Vendors > Flyrx7's Pod works
Flyrx7's Pod works flyrx7@aol.com (WA) Specializing in 3rd gen gauge pods
Old 01-26-2009, 01:43 PM   #1
neit_jnf
Boricua!
neit_jnf is on a distinguished road
Talking Quad-Pod gauge setup - prosport white/amber
FlyRX7 center speaker 52mm quad pod - THANKS FRANK!!!!
Hey Frank, I lost a set screw and I need the spacer rings since the prosports are really deep. I got around it by using the gauge's included hoods to cover them but still.
Gauges: AEM UEGO, Boost, EGT, Oil Temp
for the EGT I will install a O2 bung to 1/8 npt adapter to use the stock O2 sensor location. I know it's not the optimal location but I plan on installing it in the rear exhaust runner pre turbo some time later when I get around to pulling the twins.
for the oil temp I will use a Oil Pan drain plug to 1/8 npt adapter to get the temps. I'm used to this location since I was using a VDO that had the sender integrated in the oil pan drain plug.
neit_jnf is offline   Reply With Quote
Old 01-26-2009, 01:47 PM   #2
Slightly off topic..
Does AEM read before 11?? Maybe digital read out reads below 11?? Just curious...
Old 01-26-2009, 01:56 PM   #3
neit_jnf
Boricua!
it's kinda confusing but here goes
the leds sweep range is 11-17
the digital display 10-18
and 10-20 in the 0-5V linear output that I use with the datalogit
Old 01-26-2009, 02:24 PM   #4
Cool! Good to know.. I always wonder about that.. Thanks for the answer!
Old 01-27-2009, 07:37 PM   #5
N3philum
Unreliable Like a Rotary
N3philum is on a distinguished road
i got the spacer rings from frank for my gauges but my gauges are not deep enough to use them they are still new in the packaging. i have 3, so you might need 1 more but yah.. let me know if your intersted. I just took the gauges out of my car since i am working on selling it... maybe.... anyway, i can get pictures of the gauges in the pod but they will not be installed.
N3philum is offline   Reply With Quote
Old 01-28-2009, 12:04 PM   #6
Flyrx7
Flyrx7's Avatar
Flyrx7 is on a distinguished road
However, that won't work for Neit, as your rings are for 60mm and his pod is 52mm.
Justin, if you want you can send the rings back for a refund. If you want smaller rings to work I can do that too, just let me know what depth your gauges are.
Regards,
Frank
Flyrx7 is offline   Reply With Quote
Old 01-29-2009, 03:03 AM   #7
N3philum
Regards,
Frank
ahh.. didnt realize his was 52. I have gauge hoods on my defi gauges. that with the pod is all i need. the spacer would have to be about 1/3 the size of the one you sent me already. (width of course) I have no reason for them, and am actually (unfortunately) in the process of selling my car. I will be leaving Japan in appx 3 months and I have to get rid of it or strip it and ship it as a track car. I am unsure of what i should do.
Ill get the rings sent back to you. Can you PM me your addy? I think i threw out the box already Ill try to get pics soon. My work schedule coupled with my last 3 college classes is killing me.
Old 01-28-2009, 04:15 PM   #8
neit_jnf
Boricua!
thanks guys! I'll stay as it is for now and see how I like them this way, the hood thingy covers the "excess" gauge quite well...
